Question about HP LaserJet P2015 Printer
Printing problem "PCL XL error"
Using MS Vista. Intermitent error code when printing.
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndChar
Position: 23
  • 14 more comments
  • Anonymous Mar 06, 2008
    "pcl xl error subsytem kernal illegal operator sequence operator end char position 23".
  • Anonymous Apr 25, 2008
    Error when printing
  • TurboTek Jun 11, 2008
    We use a Toshiba Techra 8100 laptop with Windows XP Professional Operating System. We have a HP4200 Laser Printer and a HP690 connected to its parallel port via a switch box. this arrangement workd fine until we decided to install a Canon Image Class MF4140 Multi-Function Laser Printer through the USB port. The Canon works fine as a printer but we now get an error message:
    PCL XL error
    Subsystem: KERNEL
    Operator: EndChar
    Position: 7
    We think this has something to do with the LPT1 USB (ECP Printer)assignment.
  • Anonymous Jun 20, 2008
    Same error here. Receive error when printing a mail merge, will work fine for say 30 or so but will then come up with the error. Otherwise it seems fine.
  • PhilyaBoots Jun 26, 2008
    PCL XL ERROR, Kernel, Illegal Operator Sequence, EndChar, 25
    HP 4250TN intermittent, error, no observable pattern
  • nyox Jul 22, 2008
    I have the following problem
    subsystem: IllegalTag
    Opperator:0*5
    position:1804
    please help
  • shanavasak Jul 31, 2008
    PCL XL error
    Error : Illegal Tag
    Operator : 0x1b
    Position : 6
  • Kassoum Aug 13, 2008
    PCL XL error
    Subsystem: KERNEL
    Operator: EndChar
    Position: 23
    Need some help
    Product: HP laserjet P2015 serie
    OS windows Vista
  • CarService Nov 05, 2008
    I am having the same problems although the customer that uses Vista won't print at all. I found your instructions very helpful although we do not use the ports listed. We are using a TCP/IP port and the port will not configure properly to allow it to be used. Please help
  • bavk Dec 13, 2008
    Trying to print labels, but get the PCL XL error message:
    Subsystem: Kernel
    Operator: EndChar
    Position: 24
  • bavk Dec 13, 2008
    PCL XL error
    Subsystem: KERNEL
    Operator: EndChar
    Position: 23
    Need some help
    OS windows Vista
  • mgeorgegt Jan 14, 2009
    Having the same problem
    PCL XL error
    Subsystem KERNAL
    Error: Illegaloperatorsequence
    Operator : Endchar
    Position : 27
    Using Vista, but have a laserjet P3005N. will solution below about installing an old driver also help me?
  • Anonymous Apr 27, 2009
    Solution #5 ... ummmmm why don't you read and think things through before you type?
    HP said "From your e-mail, we understand that you are unable to install the HP LaserJet P2015 printer software on your Windows Vista, notice an error: "extended attributes are inconsistent"."
    This was not the original query.
  • Anonymous Mar 17, 2014
    pcl xl error position 1022
  • Anonymous Mar 28, 2014
    error for printing PDF document
    pcl XL error subsystem KERNEL File no 8958
Here are the steps to remedy the problem:
1.right click the printer and go to the properties.
2.click on the advanced tab and uncheck 'enabled printing features'
3.click on the general tab and click on 'printing preferences'
4.click on the 'advanced' tab and disable the 'print optimizations'
hopefully it works for you guys.
cheers.
Posted on Sep 02, 2008
When printing more than 1document in MS word, I get the
following error: PCL XL error
Subsystem: KERNAL
Error: IlllegalOperatorSequence
Operator: EndChar
Position: 23
Posted on Aug 12, 2008
    Problem Solver:
  • 7 Answers
FIXED: PCL XL error when printing to a HP printer
I fixed this problem by installing the KB948046 Hotfix from Microsoft (thanks to Brent Follett from forums11.itrc.hp.com for pointing me in the right direction).
To download and install this hotfix, search for “hotfix KB948046” or go to http://support.microsoft.com/kb/948046 and click on “view and request hotfix downloads”.
You will be prompted for an email address, the URL for the hotfix together with a password will be emailed to that address.
Install the hotfix and reboot the system. The problem was fixed for me at this point.
I tried to print before rebooting, but that did not fix the problem, a reboot is essential.
More information:
I encountered this problem on a HP 2605 (laserjet) printer (HP2605) that was shared from a Windows Small Business Server 2003 with Service Pack 2 (SBS SP2).
When printing from networked machines the error was printed out on the printer. After installing the KB/948046 hotfix on the server only and rebooting the server, the problem was fixed.
I also installed other updates on the server before installing the hotfix using Microsoft Update.
For more information visit http://www.brightvisions.co.uk
If you don’t have a website yet, visit http://www.set8.net and if you have a website list it on http://www.searchourworld.com
I hope you found this useful and this fix works for you. Happy Hunting!
Posted on May 19, 2009
Dear HP Customer,
Thank you for contacting Hewlett-Packard's Commercial Solutions Center.
From your e-mail, we understand that you are unable to install the HP LaserJet P2015 printer software on your Windows Vista, notice an error: "extended attributes are inconsistent ".
Please note that currently, a complete driver solutions is not available for your product. However, we do have an alternative driver solution that you can conveniently find in Microsoft Windows Vista. This driver will enable your product's basic functions to work and can be used until the full driver solution is available.
We suggest you install the native driver for the HP LaserJet 1320 printer. This driver would be compatible with your printer and support basic printing functionality.
The steps given below will help you in installing the native printer drivers on the computer:
1. Turn on the printer first, and then turn on the computer.
2. Close any screen savers, virus protection programs, or other software programs running on your computer.
3. Click Start, Control Panel and select Printers under Hardware and Sounds in the Control Panel Home window.
4. Click Add New Printer, the Add Printer Wizard appears.
5. Click Add a local printer.
6. Select the Use an existing port check box.
7. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next.
8. Under Manufacturer on the Install the printer driver dialog box, select HP.
9. Under Printers, select the HP LaserJet 1320 driver for the printer and then click Next.
10. In the Printer name text box, type the printer name and then click Next. The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of your printer, if desired.
11. Complete the installation.
12. In the printer folder, right-click on the name of the printer and then click Properties.
13. Click the Ports tab.
14. Change the port from LPT1 to USB or DOT4.
Try printing a Driver test page to check driver functionality. To do so follow these steps:
1. Click Start, Control Panel and select Printer under Hardware and Sound in the Control Panel Home window.
2. Right the HP LaserJet 1320 printer icon and select Properties. 3. Click on the Print Test Page button.
HP expects to complete the certification process for applicable software soon enough. Solutions will be posted as they become available.
We would like to let you know that HP aspires to provide the most up-to-date information on HP drivers and software. You may visit the following URL to receive e-mail updates from HP when a solution is available.
https://h30046.www3.hp.com/subprofile.php?SUBSCRIPTION=DRIVERSIGNUP&regi
oncode=NA&langcode=USENG&jumpid=in_SC-GEN__driverBSC&subs=DRIVERSIGNUP
We regret any inconvenience caused and sincerely appreciate your patience in this regards.
If you have any other questions, please write back to us. We will be glad to assist you.
Once again, thank you for contacting Hewlett-Packard's Commercial Solutions Center.
With Regards,
Michael P
NOTE: Our advice is strictly limited to the question(s) asked and is based on the information provided to us. Problems and solutions may depend on the nature of your system environment and various other parameters that are unknown to HP; therefore, HP cannot assume any responsibility or liability. Please be advised that technical information changes as new data becomes available, therefore, HP recommends that you check back at our technical support web site located at http://www.hp.com/country/us/en/support.html regularly for possible updates. Hewlett-Packard shall not be liable for any direct, indirect, special, incidental or consequential damages in connection with the use of this information.
Posted on Apr 07, 2008
Solution #4 ... ummmmm why do you ask such stupid questions.... this is clearly a driver issue.... Printers require drivers just like all other devices installed in a computer....
Posted on Sep 20, 2008
Why is the answer given about driver installation, but the problem is about printing?
Posted on Aug 14, 2008
3 Suggested Answers
jeffdynamics
  • 18 Answers
SOURCE: Printing problem "PCL XL error"
reinstalled driver w- pcl
Posted on Apr 14, 2008
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
Posted on Sep 14, 2008
Problem in printing
Dear
As the OS is different do load the driver at vista pc.
Thanks.
Feb 24, 2015 | Laser Office Equipment & Supplies
Printig problem
This is an driver (in some parts memory) problem.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1258893
Author Subject: PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence favorites_add.gif Clinton Griffin
Aug 13, 2008 02:59:02 GMT I purchased a HP Color LaserJet CM1312nfi MFP and connected to my HPLaptop with Vista 64-bit operating system and received the followingerrors when trying to print from most applications:
PCL XL error
Subsystem: KERNEL
After many hours of reinstalling the drivers, the firmware, on thephone with Microsoft and on the phone with HP to no avail, I discoveredthe work around myself.
I downloaded the HP Universal Print Driver Series for Windows Vista 64-Bit and this driver works! Here is the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=
us&prodNameId=3271558&prodTypeId=18972&prodSeriesId=503548&swLang=8&ta
skId=135&swEnvOID=2100
This solved my problem and hopefully it helps you.
- Clint
Aug 15, 2008 23:27:43 GMT Unassigned
Clint,
Just so you know what you were dealing with, as it may resurface, seeboth of Chris H's replies in this thread. Since the error was the same,it was a driver fault, and replacing the driver, not necessarily thatspecific UPD driver, that fixed it.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do;HP-FORUMS-S-WPA-IDX=H37N4f36mF4yp5t5NKsNBSL4PnhvrlHJnkHP21LmvMQkc43snv3j!-204454619
6!-1667575472?threadId=1203940&admit=109447627+1203190733494+28353475
I'm glad it's working for you.
Pat
Sep 19, 2008 03:31:26 GMT Unassigned
Update:
I continued to look at the issue and now think the problem is not thedriver, but the application software. Using the 64-bit driver for theCM1312:
1. I can print color using Paint and text using Notepad.
2. I cannot print from Adobe 9, IE 7 and Office 2007 (downloaded 9/17/08) in color. If I do I get the
PCL XL error
Subsytem: KERNEL
Error: Illegal Operator Sequence
Operator: EndSession
Position: 15
3. I CAN print all the products in 2 if I switch to grayscale.
4. I can print screen captures from the products in 2 using Paint -which may be my workaround until HP and Microsoft get together on asolution.
So does anyone from HP monitor this and report the issue and resolve it?
So theThe problem for me is color printing in Microsoft products.
Dec 20, 2008 | HP LaserJet 4250n Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
PCL XL error
try to go to property then setting device button PDL and try to put pcl 5e
Sep 11, 2008 | Office Equipment & Supplies
PCL XL error
this can be caused by your printer driver, please update it and or uninstall the printer first then reinstall it using an updated driver.
Aug 12, 2008 | Office Equipment & Supplies
Pcl xl error , subsystem:kernel, Error: Illegal tag
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Jul 26, 2008 | HP LaserJet 1320n Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Dear Sir
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
May 29, 2008 | HP LaserJet 1320n Printer
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
Apr 12, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet P2015 Printer Logo
27,678 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
