Question about LG Studioworks 700S 17" CRT Monitor
710s monitor wiring diagram to vga plug
I need this diagram to fit a plug on the end of th cable as it was cut off and stolen during a break in , the monitor survive the attack on it , but i can not get it right with a normal vga cable help please
  • 4 more comments
  • Anonymous Feb 28, 2008
    NO PUEDO VER BUENA RESOLUCION
  • Anonymous Jun 18, 2008
    I have the same problem with a LG T910 Monitor
  • Anonymous Jan 02, 2009
    how bout posting a dia
  • Anonymous Mar 26, 2014
    I need a diagram to connect a VGA cable with monitor because the VGA konketort cut off and does it. It takes a new VGA solder.
    I need a diagram to connect the VGA cable from the monitor, because the VGA konketort cut off and does it. It takes a new VGA solder
    I need a sheme to connect the VGA cable from the monitor, because the VGA konketort cut off and does it. It takes a new VGA solder
    Problem Solver:
  • 7 Answers
I searched the net for vga diagram and got this http://myhometheater.homestead.com/vgacable.html
Posted on Jan 24, 2009
DRIVER OF MONITOR LG 710S
Posted on Feb 28, 2008
SOURCE:
All my wires in my monitor r unhooked where they go can you tell me.
If your wires are unhooked, Usually new monitors wires are colour coded , for example, blue to blue, yellow to yellow etc.
If your wires are not colour coded, There is only one way the wires can go, They won't fit just anywhere. If they fit into one connector, then that will be where it needs to go.
Hope this helps
Mar 13, 2011 | E-Machines T2642 PC Desktop
Hello, The VGA cable broke. it was cut off and now it's lost. I can put back a VGA connector however I need a wiring diagram so I can know what color goes to which pin. Can you help? Thanks.
Not knowing which monitor that you have I will have to be a bit general. If the cable disconnects from the back of the monitor then you can simply replace the cable with another vga cable. If the cable does not disconnect then my best advice is to look at the other end of the cable and get the pin out from the controller board on that end. Unfortunately that procedure would require opening up the monitors case.
http://pinouts.ru/Video/VGA15_pinout.shtml
The above link will also help as a reference. However keep in mind that some of the colors may not match. Which is why you would need to check the other end of the cable to be sure. Good luck.
Aug 25, 2010 | Computers & Internet
The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Jun 03, 2010 | Envision H170L Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
ACER AL1715ebm LCD MONITOR BAD VGA CABLE
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
View sonic g220f
If both ends of the cable are plug in type, any monitor cable with a 15 pin D connectors will work.
Search internet for VGA cable.
Jul 30, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Data Cable cut on ACER AL1715sm
Hi, I have AL1716 so pretty the same - both cables (power and analog VGA cable) are inserted into sockets, probably your VGA cable can be screwed in - just unscrew it and go to nearest PC shop to buy new one. What a good cops you have !!
Oct 14, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
LG Studioworks 700S 17" CRT Monitor Logo
2,699 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
