Question about Cyberhome DVD Recorder - DVR1600
A Connection Cable
Where can I get to purchase a connection cable for my DVR 1500? The cord is ripped and I cannot find an identical cord to it anywhere.
Any standard set of A/V (Audio Video) cables should do. Check Wal-mart.
Posted on May 02, 2008
Lost signal from dvr to vizio tv and need to know what type of cord is used for this connection
That would have to be either a HDMI cable similar to usb but not totally rectangle or the old 3 lead RCA to RCA cables which are red and white for audio and yellow for video.
Apr 14, 2014 | Dedicated Micros Televison & Video
Can any one please tell me how to connect the DVR to router in simple way. Please
Ethernet cable is the easiest way. If you can, run a cable from your router to the DVR. This may require buying an extra long cable. Once you make the connections, just restart the router and DVR in that order, your IP info should show up on the broadband set-up page, found in the DVR menu. If your router requires a password to access the network you will have to enter that into the DVR settings after the connection is set up.
If running a long ethernet cable is not practical you may find it useful to try a Home Plug device. Just follow the manufacture's instructions. Alternately, a USB wireless device that plugs into your DVR can be used. You will need your wireless security info to complete the connection.
Oct 11, 2013 | Computers & Internet
I connect usb cable but get no connection
You may have been ripped off on the batteries. As far as the connection plug in the usb cord to the computer and phone. Restart your computer with the plugs connected and it should read it.
Jul 10, 2009 | Dual Electronics N99i Cellular Phone
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Pioneer 5070HD, Onkyo TX-SR605S receiver and Cyberhome DVR 1500 connection
you may have fixed your dvr1500 by now but i just came across your signal problem today,so if it is still not working try putting a cable from the yellow video out of your 1500 to tv video in ,switch to this input on your tv and you should get a picture.after this is done set output on 1500 to composite and put into cbl/sat on amp,put hdmi cable from tv into hd out on amp, go to setup input assignment ,click on this to get monitor out,click again you get hdmi mntr flick right to switch on,put your tv to hdmi and you should have a picture.
hope this helped.
cable guy.
Sep 17, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Mar 12, 2007 | Arris DCT6200 DTV Receiver
Cyberhome DVD Recorder - DVR1600 Logo
26 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
