Question about Jensen VM9410 Car DVD Player
Parking brake after i install my parking brake wire to the dvd player, then what how do i play with the emergency brake and the brake to get it playing?
  • Birdy515 Feb 28, 2008
    I have the same problem I heard there was a sequence you have to do, I dont get a warning screen either
Yes connect the pink wire to your black ground wire of your vehicles harness
Posted on Aug 03, 2008
If you have the VM9410 then there is a way to play dvd's even when you are driving. You must ground out the pink wire in the harness. This allows you to watch dvd's even when driving. good luck!
Posted on May 05, 2008
How do you get dvd player to play? put dvd in and
there is a wire comming off the back of the radio that should be wired to an emergency brake put the emergency brake on and play movie or remove wire from emergency brake and just hook it to a good ground basically all it is is a ground wire that when the ebrake is not engaged it does not make a connection to keep you from using the tv while you are driving because it is ilegal to have the tv playing while ur driving all you need to do to bypass it is find the wire and just ground it to a solid ground if you had an install shop install the radio by law they have to hook it up properly or you can ask them to leave it and you can hook it up they can not hook it up so that the player plays all the time hope it helped
Feb 27, 2010 | Dual XDVD8181 Car Video Player
I just received it and installed it, it will play cds just fine, but it wont play the dvd, it says you cannot watch in this mode while driving but the vehicle is in park. How do I get the video to play?
you need to hoohup ground wire to the e brake wire of the unit. this wire is to enable the dvd to display video or attach it to the emergency brake switch.
Oct 10, 2009 | Car Audio & Video
Installed a dvd player but i can't get it to play dvds
On the parking brake under the dash is a switch at the top that actuates the parking brake light. On most vehicles most are two wire switches, but some are one wire switches. If you have a two wire switch then you can unplug it and use a test light with the ignition turned on without starting the vehicle and test the wires to see which is the hot wire and then connect to the one that has no voltage on it because it is the ground for the switch. The wire is used to detect the parking brake position as engaged before it will allow viewing of the DVD player when the vehicle is not moving. When the brake is off the DVD player will not play DVDs, this is a safety measure so the driver will not be distracted while driving. Good Luck, RAC
Apr 20, 2009 | 2003 Chevrolet Trailblazer Ext
How do u bypass the emergency brake sensor on the kenwood dnx8120?
exactly, just connect the parking wire to a ground source and your problem is solved. This hack also allows use of the nav. while the vehicle is moving.
Apr 04, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
Car in dash cd/dvd player
Most in car dvd players require a connection to the parking brake so it will not play a dvd while you are driving (in dash only). The easiest way around it is to run a 12v wire to the lead of the parking brake wire on the dvd player. With a constant 12v it should play when the ignition is in the on position.
Sep 16, 2008 | Phase Linear UDV9010 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
All you need to do is hook up the wire that goes to the emergency brake cable to a ground (anywhere that is metal).
May 18, 2008 | Jensen VM9510 Car DVD Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
176 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
