Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Will not come on?
Worked yesterday but today will not come on at all, no lights or gride?
  • lyles4ga Mar 16, 2008
    I have this same problem. The machine will not come on at all. It worked yesterday fine and today won't come on. I checked kitchen outlets, and they are working fine. I plugged the coffee maker into many different outlets and it worked on none of them.
    Problem Solver:
  • 3 Answers
Mine did the same thing. The only solution that worked for me was exchanging the unit. This unit has a 3 year warranty Call 1-800-726-0190 and tell them your story. If you do not have the receipt, the date of manufacture on the unit is the date they will use. If you live in CA you can take it back to the retailer.
They apparently know that they have a problem with this coffee maker, as they give you no hassle.
Posted on Mar 29, 2008
Maytag top-loading washer sometimes loud griding noise mvwc300xwo
The nut that holds the main biggest pulley under machine has worked loose. Depending on how long it's been grinding, pulley and splutch that gears on pulley seat against may need replacing. Use lock tite when putting pulley nut back on.
Sep 08, 2017 | Maytag Washing Machines
On my 2006 Elantra, yesterday I noticed one headlight out. Today, only the high beams work, the tail lights are out, and the cruise control doesn't work. Has anyone else had this problem?
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: xcardiag.com
Mar 12, 2013 | Cars & Trucks
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
Hi, I have a fisher and paykel washing machine model #WA37T26G and I noticed yesterday and today that the lights lit on the electronic board was 1,6,7,8...not sure if it was the same yesterday and not sure...
to work out the fault code go from right to left far right light is 1 the next is 2 next is 4 then 8, then 16,32,64,128. add up which lights correspond to your machine and then you can google that code and find what your problem is
Aug 19, 2017 | Fisher and Paykel WA37T26G Top Load Washer
Sir/mam my imation external hard disk 320 gb is not detecting in any of my and my friend systems, i tried in windows xp/7, ubuntu. but not working. blue light(power light ) is glowing, while placing...
Unfortunately, external hard drives go bad. A 320 is probably a few years old, I replace mine about every 3 years to be sure. I know it sounds funny, but things work till they don't. Just because it was working yesterday does not mean it will work today. It is possible there is a setting in your XP or 7 to keep from seeing the drive, but doubtful it changed on both systems between yesterday and today.
Oct 30, 2017 | Imation (23780) 320 GB USB 20 Hard Drive
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Printer worked yesterday and today it has no
It's a bad power supply. go to http://www.ebay.com and search for HP PSC 750 and there are numerous of new power supplies for the printer. Or, the wiring is dead inside the printer. Go to http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&lc=en&dlc=en&cc=us&product=57769&lang=en
It's either the PSU or a bad USB cable.
Jul 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Check engine light was on yesterday, off today
Ford's can store info in the computer for a while . you can take it in to a shop and have them put a code reader on the port under the dash and tell you what happened... Sometimes these codes are just a one-time event and they will clear themselves... But a reputable shop will tell you the code and if it's a worry or not. Let me know.
KEN
May 10, 2009 | 2005 Ford Focus
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
66 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
