Slow draining water and leaking
My mom's washer is draining the water extremely slow and is leaking from some unknown source after the final cycle. We have the idea that the hose is jammed with something, but we can't figure out how to exactly fix it ourselves. We've looked everywhere for the manual but it's no where to be found. If you have any advice, ideas or diagrams that could help us out trying to unjam this thing, it would be really appreciated!
  • 2 more comments
  • DahnaB Feb 24, 2008
    it's a frigidaire fwx223lb sorry for not including that
    and thank you Kev
  • DahnaB Feb 25, 2008
    Thanx Aborcass but we can't seem to find where to open it up, the front doesn't seem to have any screws so they tried the back, but even after unscrewing everything they still can't get it off
    but as soon as we open it up I'm almost positive that your advice will help us fix the problem, thank you very much again!
  • DahnaB Feb 27, 2008
    You were a huge help aborcass!! Thank you so much (:
  • Ron Coons
    Ron Coons May 11, 2010
    who makes the machine and whats the model number?
  • Washing Mach... Master
  • 2,651 Answers
Before you calll that service guy id open the front pull hte hose off the pump inlset and look for the sock or oher item that is likely blocking it.Spinning with more water in it then its suposed to have will cause water to splash over top of tub
Posted on Feb 25, 2008
  • Ron Coons
    Ron Coons Feb 26, 2008
    looked up that model. There are 2 screws on the bottom of the front panel, then placeing a scrwdriver betwen the front panel and the main top(maybe 3 in. in from each side) theres ac lip that neds to be popped, top lifts back and front lifts off.
    Problem Solver:
  • 7 Answers
It needs to be inspected by an appliance repair guy. Your water pump may have a loose coupling causing low pump pressure, or the path water takes out of the machine is blocked.
Posted on Feb 24, 2008
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
Spins slow, does not drain and leaks a little.
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
The water is slow to drain and over night the washer filled up with water when it was empty and suppose to be off?
Replace the water valve on the washer, it is leaking water into the unit. Remove the drain pump and clean out any blockage causing the slow drain.
Sep 29, 2009 | Whirlpool Washing Machines
After the final spin cycle, my clothes are still wet.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 21, 2009 | Hoover HTC243 Top Load Washer
My machine still has water and the final cycle
Aug 10, 2009 | GE Washing Machines
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Spin cycle is slow, cloths still extremely wet after spinning
problems with spin cycle could be due to variable reasons.components involved are the lid switch, timer control and the motor.The clothes might be soaked because there could be a drain problem.check whether the drain is clear for partial blockage.also inspect the water pump.
Dec 13, 2008 | GE WWSE5240G
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Final spin cycle for kenmore 417.40042990
This is an interesting problem. How long does it have to sit before you can get it to spin? Can you let it go through the cycle and then immediatly put it into spin and it work? This machine will not spin until the pressure switch senses the water has drained. So you could have a slow drain, a clogged pressure hose, or faulty switch. A clogged hose or faulty switch would usually cause it to fill with more water than normal also. A slow drain is most likely, check the drain hose when it is draining and see if it is putting out a strong flow or just slowly draining. I think you will find it to be slow. This will cause it to take up all or most of the spin time trying to drain the water. If it is slow draining, check the pump for a sock or some obstruction. If the drain is good, remove the top and remove the rubber hose from the pressure hose and blow through it. You should be able to blow through it easily. A restricted pressure hose will cause the machine to think it has water in it after it has drained.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
