Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Thread breaking Let me first explain ...I was embroidering and the bobbin thread got all narled up took it apart an it was all around bobbin case, i took the whole bobbin works apart cleaned the thread out and noticed that there is a rubber washer under the bobbin case, this rubber washer is kinda messed up to. Do I need to replace this rubber washer......put it all back together and now it is breaking thread. If i need to replace the washer where can I purchase one? The silly bobbin case is plastic of all things, It jumped and jammed and then threw everything out of sync, the needle then hits it and voila, no good any more. I've had one already replaced through Singer rep. who wouldn't do it without cleaning, service etc. and an enormous bill. I didn't use the machine for nearly a year, now when it's out of warranties, it's jumped and jammed again, the same thing. It looks to be the timing, would you have the instructions for re-timing ? Thank-you. I'd like to know how to do it, as this seems to be an ongoing problem.
  • 4 more comments
  • singed Feb 24, 2008
    Hi the machine is Singer Quantum Futura 200 Thanks
    Hi, I've just used the emery board on a burr on the bobbin case. It was an immediate improvement, but after some straight stitching and pattern, it deteriorated to skipping near all stitching again. I am using the correct size and type needle for project and the machine is threaded correctly. I have also noted your supplier and the part availablity.
    Please note the first part of the original question beginning "Let me first explain ..............." to " replace washer, where can I purchase it from ? " was not my letter.
    My question began at " The silly bobbin case...."
    need re-timing information for Singer quantum futura c200 model please.
    Hello Mike, thanks for the heads up, unfortunately that wasn't my question, for some reason my question got tagged onto that one. I'm looking for the timing procedure for Singer quantum futura 200, as I think mine is out of sync.
    Hello again, seem to have lost you somewhere ! Yes, thank-you, I did go throught the links and have printed off what I think should help. I'm going to give the last a try now.
    Thanks, will advise.
    Genius:
  • 3,422 Answers
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Posted on Feb 24, 2008
  • 6 more comments
  • Priya darshan Feb 24, 2008
    Do you have the correct size needle for the thread you are using? are
    you using a good mercerised thread? do you have the needle in the
    correct way round,? top tension between 4 and 6 and bottom tension
    tight enough so you can pull the thread through with some resistence,
    have you got the machine threaded correctly?
    You may also check to see if there is a burr on the surface of the hook. If
    there has been a needle break, it could have hit the hook and put a
    rough spot on it. You can use a very fine emory cloth of some kind to
    remove the burr.
    Now coming to buy the part for your machine please go HERE
    and select accordingly.
    Goodluck..
    Yes i have given you all the details from where to buy it also.Please also check the things i told you just now in my above posts.
    Hi again,
    I want you to please go through THIS and THIS
    This will solve your problem and clear all your doubts.
    Goodluck once again..
    Did you visit the links which i gave you?
    OK, this is a general timing procedure. Loosen the screws on the main
    shaft gear that goes to the hook drive gear and separate the gears.
    Next put the needle in the left position and bring the needle all the
    way down by turning the handwheel. As the needle comes up make the
    point of the hook enter the scarf of the needle (just above the needle
    eye)and hold it there while you put the gears back togeather and
    tighten the screws. This should put it close to being in time. To fine
    tune it you can loosen the needle bar screw (half way up the bar that
    holds the needle) and adjust theneedle so the hooks point is just above
    the needle eye. You may have to do this a few times in order to stop it
    from skipping stitches.
    Please do reply if your problem is solved..
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
I recently replaced the bobbin case because it developed a deep groove in the side after I put it in improperly. The initial reason why I took it out was because the thread bunched up under the plate while...
the problem of your machine is, under the plate of your machine, you saw the teeth look like the used of it is to move forward the cloth u embroiderd, you should tight the bolt or nuts so that, the bunching up of thread on the plate will stop. thank you!!!!!
Jan 26, 2010 | Baby Lock Ellure
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Aug 03, 2009 | Janome Memory Craft 9000 Computerized...
Thread adjustment
Sounds like the bobbin tension is loose. Look at this website on their "repair" page where it explains how to adjust the bottom(bobbin) tension.
www.sewusa.com
Mar 05, 2008 | Brother SE-270D Computerized Sewing...
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
109 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
