Question about Garmin StreetPilot 2610 GPS Receiver
Garmin 2610 When I am trying to use the touch screen. I have to touch the screen about 1/2" to the right to get the right letter. I tried to calibrate the screen but it fails every time I calibrate it. Is there anything I can do with out sending the unit back. Maybe a reset but I don't know how Thanks
  • eurotourer Mar 06, 2008
    I have the same problem, called garmin today and they reccommend that I overwrite the firmware, I also get the same problem when trying to input an adddress, touch letter A and C gets selected, I've tried to re-cal but no luck.
  • Anonymous Mar 26, 2014
    Won't hold the touch screen calibration.
Back up the unit then do a master reset.
Switch OFF, Press Page + Menu and turn on, holding the buttons for 5 seconds.
Then recalibrate. I did the recalibrate a few times before it was OK. If you use a stylus when the cross appears and hold it on the screen and move it to the corners you can see the error. Make a mental note and go halfway between the two if it does not calibrate at first go. Then when it calibrates, do it again. I recalibrate every now and again. I think it could be a firmware problem. I will try going from 4.8 to an old version
Posted on May 06, 2008
  • joebolton Aug 24, 2010
    It happened to mine too. The solution is simple and it's built into the unit.
    Select menu.
    Select display.
    You will find a note saying press find to calibrate touch screen.
    Press that and follow the steps.
    Problem solved in a minute.
  • David Ryan Sep 08, 2011
    Thanks very much for the information. I had replaced the 2610 with a new Garmin unit in the car. As I have just got a motorbike I decided that it would be good for off road use. To my surprise I found your post and it fixed the issue with the screen, fantastic
How to calibrate garmin Nuvi 2597LMT touch screen
try poweing it on while holding the upper left corner.
Jul 11, 2014 | Garmin GPS
I cannot program anything into directions because the screen does not bring up the number or letter when you touch it, it brings up the letter/number to the left of it. You cannot get the numbers/letters...
The problem is the screen needs to be calibrated, however this sometimes doesn't work if the touch screen is failing. I saw a lengthy procedure posted here in a different solution I have yet to try. But for the calibration you will go to menu - > display -> press FIND and follow the directions on screen. If calibration fails repeat, or find the other lengthy instructions here and try those. Several people claim they have worked, again, I haven't tried them. Another option is to purchase a remote for the unit. I have one and use it for mine because my screen totally failed. I have since replaced the screen with a junk unit I purchased on EBay but prefer the remote over the touch screen for most things. Remotes are about $30 bucks. If you're lucky you might be able to find a 2610 that includes a remote for around $50 and pick up an extra set of accessories. Good luck and post back if you have any other questions.
Mar 18, 2010 | Garmin StreetPilot 2620 GPS Receiver
It is not aligned with the keys or letter or icons
Try a screen calibration. To recalibrate your c-Series touch screen follow these steps:
1. Begin with the unit turned OFF and unplugged from a power source.
2. Power the unit ON, continue to hold the Power button for 1 minute.
3. A screen will display instructing you to Press dot in the lower left corner.
4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
5. Your unit should now function normally.
Sep 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Calibration is not right on my garmin 330
If you think the touch screen is not responding properly, press and hold the Power button until the
Calibration screen appears. Follow the on-screen instructions.
Aug 15, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
When type a S on my Garmin 2720 Get a T
try recalibrating your touch screen. I had to do this on an old 2610
Aug 06, 2008 | Garmin StreetPilot 2720 GPS Receiver
Touch screen
I havn't tried this yet but I will tomorrow.
Per the Manual,
To calibrate the touchscreen:
  1. Press the remote or unit MENU key.
  2. Select Display
  3. Press the remote or unit FIND key to begin calibration.
  4. Follow the on-screen instructions
Hope this helps!
Aug 04, 2008 | Garmin StreetPilot 2620 GPS Receiver
Garmin 2610 'ok' doesn't work
Try brush around the edges of the edges and work out dirt.... Let us know. See other posts...Same problem with screen touch system not responding.
Nov 10, 2007 | Garmin StreetPilot 2610 GPS Receiver
Touch screen doesn't work and won't calibrate.
Thanks for your instruction. I have a Garmin 2610 and have the same problem with you. I I got the same message like you using with pen but with my finger it worked!!!
Please try to use you thick finger!!!!
Oct 19, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touchscreen problem
your screen needs to be recalibrated Press the "Menu" key Select Display When the "Automatice Brightnesss comes on the screen Press the "Find" Key, follow the instructions you will have to touch the dot that comes on the screen about four times and then you will be able to touch all keys when completed
Aug 22, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
624 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
