Question about Electronics - Others
Flash drive I bought a pny 4GB PNY Optima Pro high-speed USB 2.0 drive. My computer recognizes it enuf to put it on the task bar to eject or unplug but that's all. It won't recognize it at all from the port on the front of the pc.
Fddfdfdfdfdf
Posted on Nov 04, 2008
    Genius:
  • 1,019 Answers
What operating system are you running ??
If it,s windows 98 you,ll have problems, as they don,t like mass staorage devices, even with the drivers installed.
the other alternative, is to try on another PC And format it to FAT/FAT32 Or NTFS ( if your using XP )
Mike @ Compurepair.
Posted on Feb 24, 2008
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I have this my pny optima sdhc 4gb and it freezes my pc when I want to get the pictures off or the videos. Works fine if I use my usb cord to the camera, but I want to know why it wont work just from the...
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
May 07, 2010 | PNY 4GB Secure Digital High Capacity...
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
MEMORY CARD ERROR
What photo printer are you using?
It might not be able to read the High Capacity Memory Card. Check the user manual it should say what size and type of memory cards it is compatible with.
Aug 04, 2009 | PNY 4GB Secure Digital High Capacity...
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Drivers
Go to ADD HARDWARE and try to force the install.
Just so you know, Optima Pro Attaché USB 2.0 Flash Drive was designed with Windows Vista in mind, and works in conjunction with new SuperFetch (intelligent caching) to enhance system performance for quicker startup and windows multi-tasking.
But it's also compatible with most PC/MAC laptop and desktop computers with available USB 2.0 port (Backwards compatible to USB 1.0).
Jun 30, 2008 | Computers & Internet
Electronics - Others Logo
224 people viewed this question
Top Electronics - Others Experts
Sunday Ojelabi
Sunday Ojelabi
ka4iup
ka4iup
Vladimir Frolov
Are you an Electronics - Other Expert? Answer questions, earn points and help others
