Question about Kenmore 28075 Bagged Canister Vacuum
No hose suction with replacement bag
Worked fine for years. New number for bag --- "I" --- says it "replaces bag 50570" (correct number we bought for years).
"Pulls" fine --- but no suction at hose. No apparent leaks. No blockage in hose...
  • radar293 Feb 24, 2008
    Thanks --- good idea. But already tried --- "pulls" fine without bag but no blockage --- more like "sucking air" with bag.
    Have isolated problem to hose collar --- swapped hose ends and it works ok. Yet, as soon as I attach fixture to hose end (same end that caused leak at vac --- it starts "sucking air again".
    No visible damage to collar. Great suction now --- but generally useless since I can't attach any tools.
    Guess replacing the "collar" should fix --- tried duck tape & cutting hose for new fit with no luck. Good luck finding collar I guess.
    Any ideas appreciated.
    Problem Solver:
  • 7 Answers
The Bag must be blocking the port it connects to. Remove the bag and close it up. Test it again with no bag in it. If you have suction now, the bag is blocking the port. Maybe it is the wrong type, or installed wrong.
Posted on Feb 24, 2008
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
Vacuum doesn't ****
Assuming the unit (motor) runs ok and since it used, you may need to disassemble it and check the suction right at the motor. Sometimes there is a filter screen in front of it that can plug. The motor impeller could be partially obstructed or dirty, reducing the vacuum force. The bag should be the correct one for the unit or suction can be lost if it doesn't fit correctly.
Mar 28, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover Portapower hose won't stay on, when it does poor suction.
In reply to the problem you have about the hose not staying attached very well, we had this problem years ago with one of our old cylinder vacs. Sometimes after several years of the hose connector being rotated to attach/remove it from the machine, the lugs that lock it into the hole can wear down or become mis-shapen as they are only made of plastic.
I have a UK model Hoover Portapower and luckily have never had this problem as I hardly remove the hose at all (except when emptying the bag). If you remove the hose from the machine and have a look at the connecting part of the hose where it attaches to the machine, there should be two lugs/clips either side of it. If these lugs look a bit mis-shapen or the plastic on them looks worn, then the hose will not fit the two slots either side of the hole on the inlet fully hence the hose being loose. The only way to cure this problem is either put a little bit of electrical tape on them which will stick the hose to the machine better as that's what we did. Overall though you are probably best replacing the hose for a new one if this is the case as these lugs will then be the correct shape to fit the machine properly on a brand new one :)
Mar 04, 2009 | Hoover Portapower C2094 Bagged Canister...
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Kenmore 28075 Bagged Canister Vacuum Logo
259 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
