Question about GE 29385GE1 Corded Phone
29385 GE Speakerphone
I was unable to answer this phone, either by speaker or by handset, until a week ago, when I realized there were batteries to be replaced.
Now with the new batteries, I've developed the same problem. Is this a problem with the phone, or with the batteries?
  • btts Feb 25, 2008
    A break-in period for new batteries is not something I've ever heard of, but I guess it makes sense. Thanks.
Can not speaker phone
Posted on Mar 31, 2008
New batteries does not mean GOOD BATTERY.
Did you test the replacements?
There are batteries that come with a tester in the package. A small sheet of paper with a color coded bar to tell you much like a pregancy test, if the battery is good, before you leave the store.
Never use a new battery after insertion without a full 12 or more hour charge from your phone charger. The batteries are good enough to draw dial tone when new but have been setting in that package for a long time and NEED the initial rebirth charge.
Hope this helps.
Posted on Feb 25, 2008
How do i check my phone messages
The 29385 isn't an answering machine.
Consult the documentation for whatever answering machine you have on your phone line.
If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Nov 12, 2014 | General Electric Ge 29385ge1 Corded Phone...
Phone turn off when speaker is turn on and it disconnect when it turns off
If it is the handset speakerphone, this usually means the battery is dying. The speakerphone uses more power than the regular phone, so when you turn on the speakerphone with a weak battery the handset will shut off and disconnect the call. You likely need a new battery.
Mar 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
At&t 3358 base speaker is not working
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with phones.
Jan 20, 2011 | AT&T 5840 5.8GHz...
Speakerphone
CLICK HERE for a copy of your Manual in PDF format.
The answer to your question is YES - the speakerphone on the base will work with the handset in the cradle.
Press SPEAKER to operate.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 03, 2009 | GE 25953 Cordless Phone
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
My ge phone 900MHZ, cordless speakerfhone cw id model 26936GE1-A SN 00084148. SPEAKER WORKS, BUT HANDSET SAYS "no line to base" line is securely attached, speakerphone works
I need a replacement part for the phone model 26955 cordless handset and corded speaker phone. The part is called a handset hook that is used to hang this phone on the wall.. I would like to purchase this piece for the missing piece that did not come with my phone. Can you help me find this piece.
Jun 28, 2008 | GE Lands Phones
Telephone
It was changed automatically after someone left a message on caller ID.
Mar 09, 2008 | GE Lands Phones
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Phone problem
I lost my manual for my GE 5.8 cordless gigahertz phone, and don't know how to program numbers in it. Can you please help me out?
Nov 30, 2007 | GE 25952 Cordless Phone
Ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Aug 27, 2007 | GE 25951EE2 Phone
GE 29385GE1 Corded Phone Logo
208 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
