Question about Jwin JT-P33 Phone
Phone is chirping
Bought a new jwin jt=p33 phone. for some reason it randomly "chirps" its ringer circut. Why is this happening?
Most phones chirp.
1. Low battery........NEEDS a 12 hour or more charge from phone charger.
2. Loosing signal.
3. Electrical interference.
4. Some set communicate with the base for freqency signaling and change channels automatically when interference occurs. The chirp is to autonotify the user.
Most importantly, think about the situation when chirps occur and write it down. At some later date, compare your notes and you'll find your culprit.
Hope this is helpful.
Posted on Feb 25, 2008
How do I get my alarm system to chirp instead of beep when it goes off or when I lock my doors with the remote entry key fob?
Check to see if your vehicle honks when you press the "lock" button on your key fob. Press the "lock" button multiple times in a row. Many devices won't beep unless you double-tap the button after locking. If the horn doesn't honk, but the lights flash, your chirp feature is probably disabled.
Use your keyless fob and ignition key to enable the audible chirp. The process varies considerably on different makes and models. You must usually consult your owner's manual, a dealership or the alarm manufacturer for the correct process.
Jan 29, 2015 | 2006 Hyundai Tiburon
Why does my viper alarm suddenly start chirping?
Mine does that too (chirps 8 times), every 4 to 8 hours or so (seems to be random but persistent). The alarm was installed November 2014 and I just started noticing it in May 2015, possibly because I am now within earshot of where my car is parked?
Apr 28, 2012 | Viper Security and Remote Start System...
My house lost power and when it came back, my phone is now chirping every 15 seconds. I lived hear for 2 years with this phone and always had the ringer set to off. Its never done this before. I do not...
The phone has lost contact with the base phone when the power was disrupted. so the best way to reset is to remove the power from the base phone - remove the adapter, remove the battery from the hand unit . Now reset and connect the power while it must MESH up. If not try to use the intercom call. If the phone does not mesh then there can be error in the base phone.
Please repeat this once again.
Jul 27, 2011 | Northwestern Bell 35807-4 Cordless Phone
1995 deville when remotes are used NO horn chirp or light flash
When the car was built they did not have the chirpping option. I had owned a 95 & a 96 both purchased new and that chip you will not here from a factory unit. Maybe aftermarket has that option if you know someone with the chipping noise in their Caddy. I also worked at a Caddy dealership for 7 years and never heard one chirp in any 90's model
Jan 13, 2010 | 1995 Cadillac DeVille
Why does my viper alarm chirp for no reason sometimes?
well if it only seems to do it when u go into places where u can not hear ur alarm when it sounds then more than likely its telling u that the alarm had been tripped. Most alarm systems have that feature that it just chirps every so many secs to let u know.
Nov 03, 2009 | Viper Security and Remote Start System...
The phone makes a high pitch screeching sound
if you have recently added dsl or moved the phone and you have dsl (hi speed internet) make sure there is a filter on the phone.
Sep 07, 2009 | Jwin JT-P33 Phone
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
Tv wont turn on
A high pitched chirp is a sign that you have a short on the load of your power supply. I just finished repairing one of these sets and it had a shorted horizontal output transistor and a bad flyback transformer.
Jan 10, 2007 | RCA F32444 32" TV
Jwin JT-P33 Phone Logo
318 people viewed this question
Top Jwin Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Jwin Lands Phone Expert? Answer questions, earn points and help others
