Question about Toshiba Satellite Pro M15-S405 Notebook
Continuous loop and cannot charge battery
My Toshiba seems to go into a loop and the screen freezes. I must shut down by pressing the 'start' button.
The original battery would not charge so I replaced the battery but I still must use a power adapter.
I have started fresh several times using my recovery disk. Each time I immediately installed Norton Security. The screen freezes when I add software and updates. Windows service pack 2 caused the screen to freeze.
Do I need a new hard drive or new ram?
  • rwilliams146 Mar 03, 2008
    I only have the battery charging problem. The laptop works fine off of the AC adapter and will work off of a charged battery however, the battery will not charge.
    I purchased a new battery and from the factory it had a fifty percent charge. I let the laptop charge overnight but the battery was still at fifty percent the following day. I ran the laptop off of the battery down to thirty-six percent.
    Still not indication of charging.
    Thanks,
    Randy
    President:
  • 778 Answers
Windows service pack 2 is a huge update and takes a long time to complete, I will suggest walking away from your computer and having lunch, go to sleep, watch a movie, etc... while the update finishes. If you have already done this with the same result? I would look for a Windows XP SP2 disk (XP with service pack 2 integrated) and try that. Otherwise Microsoft sent out many disks containing the SP2 update itself on a disk, and you could try the SP2 update from one of those (if you can find one) after your clean install.
Good luck.
Posted on Feb 24, 2008
Samsung Galaxy Note 4 - Stuck in a power up loop
Samsung Galaxy Note 4: power on off loop:
I have a Note 4 also.. When I updated to one of the newer OS it started power on off looping when the battery got to a low percentage. This would freak out any User. It is normal for many people however. It is a Google software firmware issue that will probably be fixed after the next patch update.
In the mean time, if when your battery gets really low and you get the power on off loop, just charge the device or pop in a charged battery.
There is no fix for this right now. You just have to deal with it.
If your battery is higher then 15% left and it is looping, then the possibility is that either you tried to/or the system automatically tried to update your phone, but the transfer was interrupted or corrupted some how.. could be bad connection between the towers or the WiFi router you were on.. or any number of other things.
If you are in the US, best to drop by a local Best Buy store. Call ahead and ask if they have a Samsung Experience Shop inside. Not all Best Buys have one.
Ask to have Best Buy transfer your call to the rep there if possible (I'm not sure if they have a phone there.. if not you may have to just visit the Best Buy store with the Samsung Experience Shop inside there..
Bring your device and your charging cables/adapter just in case, make sure the battery is charged).. Ask if the Samsung Manager can help you and when s/he will be available.
That person will have the knowledge and the equipment inside the Samsung Experience section to get your phone back to normal again, however note that you may lose all your data files on the phone. It most likely will have to be factory reset and possibly reFlashed with the OEM firmware.
WELCOME TOTHE SAMSUNGEXPERIENCE SHOP
Jan 09, 2016 | Samsung Galaxy Note 4G
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
Keeps trying to reboot
Hello My Friend::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 30, 2012 | Nokia Lumia 710
This laptop is a Toshiba SM30X-154 running Windows XP. It was switched off and not shut down and is now looping on the start up despite taking the battery and power out, using the Recovery DVD and eve
When this screen is seen with XP, the system must start up by pressing 'Enter' key. If it doesn't, the O/S might be currupted due to improper shut down. If it is the case, you have to load XP again, by inserting the system disc. Here it seems that, the system tries to boot, but fails. A clear indication of currupted O/S.
Nov 25, 2012 | Computers & Internet
My phone wont turn on
5.Wait 10 seconds.
Step
Thanks
Sep 05, 2012 | HTC Vivid
NB255 netbook. When I power it on (full battery charge) the first time I press the power button the power light comes on and my mouse lights up but the screen never comes up. I have to press and hold the...
I have the same exact issue and i only have it for less than a month. It is very difficult to turn in on again without having it connected to the cable. Even though the battery is charged. The way i found to make it work was to start the laptop with the cable connectedand then disconnect the cable after the windows has started.
Mar 29, 2011 | Toshiba NB255 Netbook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Ati2dvag caught in a loop
ati2dvag seems to have a problem with XP SP3
I don't know if you have SP3, but if you do, try rolling back to SP2
Method 1: Use the "Add or Remove Programs" item in Control Panel
1. Open the Control Panel
2. Select Add Remove Programs
3. Click to select the Show Updates check box.
4. Click Windows XP Service Pack 3, and then click Remove.
5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder
1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore and select a restore point prior to SP3
Oct 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
