Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sound Gone I try to listen to my Sansa and the soing is only coming through one earbud. I tried taking it apart but only got off the base. How can you get to the jack to repair it without indefinately screwing it up?
  • silverwolf Feb 27, 2008
    Same here, I lost the right side, I think the tab in the jack broke... Still works otherwise, can load music and whatever, just no sound on the right side... Expensive flash drive now...
  • TrekGirl May 07, 2008
    I have the same problem, except now I can't get any sound. Does anyone know how to fix this or how I should go about finding someone to fix it?
I lost the left side. Everything else still works
Posted on Apr 08, 2008
The left earbud of my new headphones wont work
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
Oct 28, 2017 | Sony Audio Players & Recorders
I want to use my Motorola Talkabout and iPod through the same earbud, is there an adapter of some kind?
Hi Dimitri,
Q. Does your Motorola have an ext speaker outlet, if so, then going the a radioshack or similar store would be an avenue, make sure you take your Motorola with you so they can give you the right adapter.
If this is successful, I believe we've solved the problem.
I hope that this solves the problem for you.
Kind regards,
Jan 15, 2013 | Motorola 53727 Earbud with Push-To-Talk...
No base sound
try getting a better pair of headphones or earbuds i highly recomend skullcandy earbuds they have exelent quality and sound
Sep 23, 2009 | Apple iPod shuffle MP3 Player
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
When I put my earbuds into my ipod touch only one side works
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
Feb 14, 2009 | Apple iPod touch
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have it twice and the sound starts sounding bad...(Base)
might be your music EQ. can make your music sound really weird.
Feb 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
One earphone works
i had the same exact problem with mine. Reading around it seems to be a common problem with the Sansa line. I opened mine up and found that one of the solder points that holds the ear phone jack to the main board had come loose. I soldered it back and it works like a charm. Pretty easy too. If you have a soldering iron, just open it up and resolder the solder point that has broken off. You can read instructions for disassembly here: When you have it apart, looking at it from the side, with the jack to the right, the broken point should be the rear (closest to the circuitry) point. You will see a very small, not sure what to call it, chip on the board you have to solder a connection to. here is a diagram: Hope this helps.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
