Toshiba 32AF13 television
I have no picture. It has sound on the DVD but no picture. I hooked another TV to the direct TV box and it is fine- picture and sound. So it is definitely the TV. I read that it might be the high voltage board that runs the picture tube. Estimated fix was $200 range.
Any thoughts?
    Scholar:
  • 135 Answers
Hi there!
It may very well be the High Voltage circuit. However, It can be the vertical or video section as well, but cost wise about the same. If cost of repair exceeds more than half the price of a new set, and considering the age, rather replace. Good luck,JUS004
Posted on Feb 29, 2008
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
Things to check:
In menu are speakers (audio area) switched on or off?
If you put sound all the way up and listen right at speaker what if anything do you hear?
If using a cable or sat box is sound turned down on it?
Is sound muted on set or the box (if used)
Do you have sound with a DVD etc hooked via the rear jacks?
A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
failing all of the above you have a audio circuit problem
Mar 26, 2012 | Toshiba 36A43 36" TV
I have a toshiba 42HL196. With HDMI cables hooked up, I have no picture when attempting to watch cable TV or use my DVD player. Everything works when I hook up using RCA cables. What is my problem?
By no picture, do you mean that you have sound? If yes then ensure that the tv and the DVD player/cable box is set to the same resolution as that of the tv. That should resolve the problem.
Dec 04, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
Audio cuts out intermittently and tv only 10 months old.
Hook the tv up without the box then use dvd etc to test the sound
If the sound works find with dvd etc hooked up then its the box
Jan 20, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Toshiba 57H81 57in. Rear Projection Please help us get started
this set has a scan converter board that causes this prob. it can be replaced or rebuilt. rebuilt is the best option. by tv tech..john
Sep 12, 2007 | Toshiba 57H81 57" Rear Projection...
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
