Had the e20 problem a few times but this time the tube blocked was right inside and we cant get to the jubilee clip - have managed to take the top off machine but cannot work out how to remove the casing - got 3 kids and need to get this back running now!!!!!!!!!!!!!help please
The whole casing splits in two, as you already have the top off, you will see four gold coloured 8mm bolts on both sides off the machine undo the two closest to the rear of the machine on both sides, there are also three more located on the back of the machine one at the top and two at the bottom, once they are removed, there are two more left, one on each side of the machine these are located behind plastic bungs,at the boottom next to where it splits in two, now all thats left is to unclip the hose inlet bracket at the top and pull the whole back end off. if you found this helpfull please leave feed back, thanks.
