Question about Motorola Mobility Moto Q
Headset i have a motorola Q and i have the ear-bud headset. The problem is, When i plug the headset in it starts to make calls by it-self and voice command asks me to say a command. it only happens when i plug in the headtset. please help me
Bluetooth will not work
Posted on Feb 24, 2008
Can't make calls
Voice Commands are dependent on your connected phone and how you press the button. HK250 Settings
Mark
Motorola Support
Jan 05, 2015 | Motorola Mobility HK250 Universal...
Constant beeping in bluetooth, and will let me use voice command to call but not text.
Cathy
This headset doesn't work natively for voice dictation unless you initiate listing via your phone. There are specific headsets that do facilitate voice to text but it is specific headsets with certain phones and may require an additional app.
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063 https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063
Dec 29, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Unable to make calls using voice commands
Try by reseting your Headset device following this steps.
How do reset the H19txt to factory default
You will need to re pair the Headset with the phone.
Jun 30, 2014 | Motorola Mobility H19txt Universal...
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
Feb 22, 2009 | Motorola Mobility S9 Headphones
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Ear hook and ear bud replacements for Motorola H375
Here a site for replacements.
MOTOROLA H500 REPLACEMENT EAR HOOK $4.50http://www.worldwidecelldeals.com/store/
Nov 24, 2008 | Motorola Mobility H500 Wireless Headset
HOW DO I MAKE A CALL USING THE VOICE COMMAND ON MY PHONE USING MY BLUE TOOTH
When the earpiece is in your ear the outside (blue part) is actually the multifuction key. Just press the button and say the command to make a call, and push the button again to hang up a call, it took me a day or two to figure that out too.
Hope this helps
Jul 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Motorola headset bluetooth h500
i can not ear auido in my head set
i installed software than i connected my device than i can"t ear any sounds on my headset
Apr 29, 2008 | Motorola Mobility H500 Wireless Headset
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
47 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
