Question about HP Pavilion A520n (DW233A#ABA) PC Desktop
Audio problem - no sound on left channel
No audio on left channel during any play/playback.
have tried both outputs front and back. have tested two sets of (functioning) speakers (both have L, R and SubW speakers) ....same problem using headphones. could this be a software problem? my local computer repair guys told me that "unfortunately with these HP pc's, if it is a hardware problem....little or nothing could be done due to the way HP configured 'the box' "...don't know if this is true or not...
any advice or help would be very much appreciated...Thanks, Mark
PS...no audio from CD drive/ downloaded music/ youtube video audio etc...i.e., no audio from any sources as far as I can tell....
  • Marstop Feb 24, 2008
    OOPS..should have mentioned this in my question ..
    Yes, first thing I did check was "control panel, sound settings, and slider is in middle or left or right..same thing with
    generic sound in tray at bottom." Thanks very much for responding so fast...got any other ideas since this is not the problem? thanks again.....
  • Marstop Feb 27, 2008
    Tried switching speakers still no left channel. I have not uninstalled /installed device drivers etc...you mentioned this as the next step....can you help me with this? Thanks muchly.
    Genius:
  • 3,587 Answers
Sure..go to control panel, sound settings, and you should be able to check if the slider is in middle or left or right..same thing with generic sound in tray at bottom.
check your warranty here for FREE
Posted on Feb 24, 2008
  • Patrick Michaels
    Patrick Michaels Feb 24, 2008
    sure..can you 'switch' the signal, so that the right side, comes out of the left side speakers. just checking for probable cause if this failure. Next thing we'll do is to uninstall the audio device from system/device manager.
    or, we can do a shared screen session. send me an email to my profile one listed.
  • Patrick Michaels
    Patrick Michaels Feb 27, 2008
    sure..go to www.hp.com and get new drivers, and install them..still figuring you have a blown sound card on one channel though
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
When I have the tuner in FM mode and select Dolby Digital the center channel is the only one that plays
Seems that you hav checked and set up rightly and the fault seems to be with the main amplifier drivers. Remove the left and right speakers and test, if these are OK then the fault can be with the outputs if there is no output even with a normal aux input .Take consensus to confirm.
Nov 07, 2011 | Yamaha HTR-6090 Receiver
The left channel of my toneport is higher than the right side in the outputs...even in the headphones its the same. When i push play with very low volume i start listening first on the left channel. I...
Check out your speaker settings in Sounds and Audio devices, in your control panel.
Start - Control panel - Sounds and audio devices - Check the speaker volume under the "volume" tab and the volume controls for audio playback under the "Audio" tab.
Jul 03, 2010 | Line 6 TonePort UX2 Sound Card
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Rear speakers won't play sound.
check on the front of the unit for a speaker selector- make sure A & B is selected
Feb 04, 2009 | Kenwood VR-307 Receiver
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Yamaha GO46 firewire audio interface
Hi. It might be a bit late, but the solution to your problem is the fact that the phones level is dependent on output 3-4. If you turn 3-4 all the way up you should be able to hear something. You might want to route all the outputs to the digital mixer.
Aug 23, 2008 | Yamaha GO46 Sound Card
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Oct 29, 2007 | Sony STR-DE575 Receiver
HP Pavilion A520n (DW233A#ABA) PC Desktop Logo
1,022 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
