Question about Mach Speed TRIO Onyx MP3 Player
Help my onyx mp3 just goes to voice when i turn it on and wont let me listen to music
  • 1 more comment
  • Anonymous Apr 05, 2008
    I have the same problem, I've tried loading the firmware from the disk and re-formating the disk and it still goes straight to voice recorder. Even if I get out of the recorder it jumpes right back.
  • lil_lucky94 Sep 10, 2008
    mine two i cant even hear the recordings it just starts recording
  • Anonymous Jan 06, 2009
    I have the same exact problem...someone please help us solve this problem!!!!
Mine does the same thing idk how to fix i can anyone please help me!!
Posted on Sep 10, 2008
Hold the menu button (the m button, in the middle), then it will go to the main menu.
Then click on the music button with the "m" but dont hold it then click the play button and then click the volume button wile the sign next to the bar that tells you how long the song is and how long it takes to get done. check the volume if you have it on pause or stop it will go strait to the record button. try it and if it dont work then srry.
Posted on May 04, 2008
I have an option on my sandisk sansa fuze mp3 player for voice recordings. There is pre-recorded literature that I would like to download, but, I only know how to download these voice recordings under...
You can't. Audiobooks are just like music, and the Sansa treats them that way. Think of them as words spoken without music.
Voice recordings are made on the Sansa, when you use it as a digital recorder. You can record lectures, meetings, or notes to yourself, and play them back.
Aug 10, 2010 | SanDisk Sansa e260 MP3 Player
How to get Music on to Onyx MP3 player?
Copy and paste the music file to the mp3.
Jan 20, 2010 | Mach Speed TRIO Onyx MP3 Player
I HAVE AN EMERSON MP3 PLAYER VERSION 3.5O.00. WINDOWS MEDIA PLAYER SHOWS THAT I HAVE MUSIC LOADED ONTO THE DEVICE BUT WHEN I REMOVE IT FROM THE USB PORT TO LISTEN TO MY MUSIC... THE MP3 PLAYERS SAYS THERE...
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Jan 23, 2009 | Emerson BAR900 MP3 Player
Problem downloading music
yea you go to i hate onyx.com than you click on this thing sucks.then you go **** your dads ****
Oct 30, 2008 | Mach Speed TRIO Onyx MP3 Player
Help
Your flash memory has become corrupted.. only the manufacturer can repair..I wouldn't try to reformat it...Never force it to run after it has shutdown from low battery. Don't leave it in high heat environment..You could try to connect it to your pc with the power switch in the off position let it charge fully and then before you disconnect turn the power switch on on the player..If thatdoesn't work make sure you are using the pc that connected to the player originally and plug the player with the power switch on and restart your pc. Good luck
Sep 10, 2008 | Mach Speed TRIO Onyx MP3 Player
MP3 player wont work SMP3332
i can't get my computer to let me put music on it!!!i need help
Nov 01, 2007 | Audiovox SMP3332 MP3 Player
Onyx
If you call the tech support line at Machspeed.com they should be able to walk you through flashing your firmware to restore operation.
Oct 08, 2007 | Mach Speed TRIO Onyx MP3 Player
Cannot access Music and Voice menus
When i turn on my mp3 player, it will only display the initializing screen and will not stop and i cant access the music menue or any other menues
Aug 27, 2007 | Audio Players & Recorders
Mach Speed TRIO Onyx MP3 Player Logo
59 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
