Question about RCA F19426 19" TV
User guide every time i turn my tv on with the remote the guide pops up and the only way i can remove it is by turning the tv off then back on manually. i want to disable the guide so it doesnt pop up any more.
If you press the "guide" button, and then up at the top where it says "schedule, sort" etc, move the arrow there, and press it to the right a bunch. eventually a column comes up called "setup", and i believe the option you're looking for is "view options". there is a "guide at startup" option there.
Posted on Jun 17, 2008
    Problem Solver:
  • 20 Answers
There should be a way in the menu were you can shut off the guide on start up.
Posted on Mar 17, 2008
F36665
Found this on page 55 of user manual. Hope it helps.
Problem:
Every time I turn on the TV, the Guide is on the screen
Solution:
The GUIDE Plus+ system automatically appears on the screen when you use the TV button on the remote to turn on the TV. You
can turn off this feature by pressing GUIDE on your remote control and then select the Menu bar. Press the right arrow button to
select Setup. Choose Review options and select OFF.
Mar 07, 2013 | RCA F32650 32" TV
The guide menu keeps popping up and it loses the remote programing. I cleared it out once by pressing several buttons, including the power and mute button simultaneously until I gained remote control...
You have bad switches inside the tv. When a switch gets stuck nothing else will work including the remote. In other words, the microprocessor can take only one command at a time. Replace all the switches at one time to avoid trouble later.
Oct 13, 2009 | RCA Televison & Video
Guide Plus keeps popping up when the remote is used to turn TV on
there should be a way to turn it off in the user menu. usually it's under setup.
Jan 10, 2009 | RCA Universal Remote Control
When I turn on my internet and TV with the universal remote the Guide Plus menu comes up as well and we can't get out of it without turning the TV off then on again manually. Is there anyway to program the...
1. When you cut on you tv the guide pops up.
2. On the tv remote there is a button that says "menu" hit that and the screen should go away, i just did it myself because i have my tv program with that Jumbo Universal Remote Control and just ran into that problem.
3. How to just program it out of the tv when its cut on all together, im on the hunt for that answer myself.
4. Try going to manufactures website and try trouble shooting for your make and model, that is what i am about to do right now. Cable tv has the guide so i don't need my tv to pop up its guide also.. you now.. good luck
Jan 05, 2009 | RCA 24F512T 24" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
TV will not turn on
Assuming you are absolutely sure the TV is getting power,
If you have an ohmmeter, measure the resistance between the two prongs on its plug. If no conductivity (over 1 meg Ohm) the fuse inside is popped. Take the cover off, look in the area near the power cord, it is the usual 5AG type (glass cylinder) fuse. If you replace it and it pops again then measure all the diodes in the rectifier circuit (near the fuse).
Many times power transients will just blow these input power devices. However, many times it will go much deeper and get the TV's processor brain. If the TV is anywhere near 10 years old, I wouldn't go any deeper than the input power circuit.
Jan 18, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Guide pop up
Maybe there is a setting for the guide in the main MENU settings to adjust when the TV GUIDE displays? Or just turn it off completely? Pretty basic answers, I know, sorry...lol : )
Nov 08, 2007 | RCA F36648 36" TV
RCA F19426 19" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
