Question about Sony (crx300e) CD-RW/DVD-ROM (Combo) Burner
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
I installed a cRX300E cD-RW/DVD-ROM combo in my computer. The CD can be read, but when I tried to read DVDs the computer sends an error: "The device is nor ready".
I tried installing the CRX300E Firmware KYS2 but it didn't work.
I will appreciate your assitance,
Thanks,
Roger
    Genius:
  • 1,019 Answers
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 24, 2008
I have dvd combo SONY CD-RW CRX300E but my problem is my drive can read cd but cannot read dvd please me to resolve this problem
Try the DVD-disk in some other computer, to see if the disk is the problem in _more_ than one computer.
Try some other DVD-disk in your computer, to see if your Sony drive can read _any_ DVD disks, i.e., if _NO_ disks can be read, then it's time to replace the drive.
Jun 20, 2011 | Computers & Internet
The problem with nero to burn the copy cd/dvd
try this one try to copy everything you want to burn through cd/dvd intothe computer then you can now burn it....
plz like if this is helpfull.....ty
May 17, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Hi , my cd rw crx300e does not respond to discs at all.i may have deleated components, all drivers are up to date,can i check this ?
make sure that the cdrw dvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw dvd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 27, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
I have a 3 dongle hardware is zte i have windows vista and everytime i put the mobile dongle in it says e:\ win32 not a valid application help!!!! please
Hi leigh_Hall86,
It seems that you're running a 32 bit version of the software on a 64 bit operating system. Or the driver is not longer supported by modern Operating systems. To fix this issue try finding and installing the right driver.
Hope this helped
-Luchen
Mar 10, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
SONY CDRWDVD CRX310Sreads CDs but not DVD.
hi
becoz you have a CD writer not a dvdRW it will burn only CD's not DVD's
both lence are diffrent
May 21, 2010 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
I have cobo drive, drive can read and write DVD's but not CD's
Hi there. You may need to re-install your drives.
Open Device Manager, click the + sign next to DVD/CD-ROM drives. Right-click on the drive and choose Uninstall Driver. Shut down your system, and restart. When Windows starts it will detect the new hardware and install the software for it.
Also, try uninstalling your burning software, restart, and re-install. It may be that the software has got corrupt.
Hope they work, and let me know if they do or don't.
Thank you
Tim
Dec 08, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
CRX300E Combo
http://www.youtube.com/watch?v=-Xr71sWVacI
May 01, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Won't recognize dvds
I think your DVD burner is faulty and requires replacing, as they are very innexpensive to replace as you wili probably know,so don't waste too much time trying to solve it. It isnt the decoder as thats a peice software that comes in certain burning programmes, the laser is able to read cds as the tracks are wider apart than dvd's and are easier to read. The drives dont last as long as they used to because, keeping the price of burners down, like anything else means cutting corners and costs and in burners cases as was the case with PS2's the lasers are cheap and soon fail.
May 09, 2007 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Sony (crx300e) CD-RW/DVD-ROM (Combo) Burner Logo
653 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
