Question about iLO 2600 Television
ILO TELEVISION MY TV IS 1 1/2 YEAR OLD 32 INCH NOW IT DOES NOT TURN ON
  • 50 Answers
Make sure that the outlet you pluged it into does not require a switch. Try pluging it into other outlets. If this doesnt work you may need to consider a new television. Otherwise you can call the manufacture and explain your problem with them. If you require any more assictance you may email me at SDZAKKMF@charter.net.
Posted on Feb 24, 2008
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
I have a 32 inch toshiba tv that sometimes won't turn on for days
You may have bad solder joints inside and around the power supply or deflection circuit. Whit the power on try to hit the side of the set to see if it makes a difference.That would confirm the problem.
Hope this will help Good luck.
Please do not rate this answer(unless it helps) as it is only a suggestion.
Dec 03, 2009 | Televison & Video
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
regards,
daniel.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
23 inch lcd tv by dell wont turn on as if no power
if this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Dec 04, 2007 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
