Cars & Trucks Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bonding agent for external car trim damage
Hi
During the recent bad weather, I like many other people slid on sheet ice and I damaged the A Bar on the front of my 4x4. The damage is not enough to consioder replacement as all that has happen is a 6" long strip of the plastic covered impact foam has come away.
The wquestion is, as I wish to repair this, what is the best adhesive to use that will bond foam to foam quickly, strongly and is weatherproof.
Thanks all.
Jeffrey Babiuk
Level 2:
Scholar:
  • Land Rover Expert 129 Answers
  • Posted on Apr 03, 2010
Jeffrey Babiuk
Land Rover Expert
Level 2:
Scholar:
Answers
129
Questions
Helped
86201
Points
250
Typically I use silicon adhesive takes some time to cure but strong waterproof.
Hi my petrol gauge is versa visa when is empty is says its full. i recently changed my petrol pump housing. im driving a polo 9n3 2008 model classic 1.6
possible damaged during work --wiring disconnected or damaged --inserted wrong or jammed when reinserted
1helpful
2answers
1995 Isuzu Trooper, The water/antifreeze froze during this cold weather. Did it totally mess something up? When I started it, it sounds like gravel going thru it.
If the mix of anitfreeze and water did not provide proper protection damage could be possible. The sound may be ice crystals and sludge. I know the temps have been in the teens and single digits. Who did the last coolant change and what was the mix. If it was 50/50 or 60/40 you should be safe.
Exterior door latch not working on a 1997 ford thunderbird latch came loose during ice storm seems to still be connected to exterior handle
You will need to pull the door trim panel off and check inside for the extent of the damage and what parts are needed.
How to remove lift gate panel to access window shield wiper
Trim panels are usually retained by a combination of screws, often retaining grab handles and other furniture, and hidden clips.
Some screws are obvious and others are hidden by blanking plugs.
A few panels are completely retained by screws and some panels are completely retained by concealed clips. A few panels are retained at the lower end by screws and/or hidden clips and then when these are released the panel must be slid upwards to unhook at the top.
Removing a panel usually breaks a few clips and sometimes it doesn't matter how carefully or carelessly panels are removed a certain amount of damage and broken clips/studs is inevitable, especially in cold weather. Sometimes considerable force is needed especially if the panel hasn't been removed before.
There are a number of special tools for dealing with trim panels and studs but these are of limited use to unskilled or inexperienced hands and of limited use to even an experienced person encountering a new model for the first time. The tools are designed to reach far behind the panel and a vee-shaped groove can engage with the stud (if it can be found) and lever it from the metalwork. Such tools don't often prevent the stud breaking but does help protect the panel from damage.
When dealing with door and tailgate panels it is well to have a selection of studs and clips available and a variety of glues, plastic welding equipment to hand as well as being able to give completing the task satisfactorily sufficient time.
2answers
Have a guarantee on the car from autoprotect. refusing to accept claim - say its due to wear and tear. True?
Depends on the component and level of protection that you purchased. Read /read your contract and see what components are covered and for how long. You never said what component is was.
Why car won't start after the gear box was taken down to replace the seal which was leaking
Hi Henry, Without knowing the make and year of the vehicle I'm shooting in the dark, but maybe on target? On recent vehicles, even back as far as the mid nineties there are a number of electrical and electronic management connections to the gear box. it could be you're dealing with a bad connection or damaged circuit. Check the area where the recent work was carried out. Regards John
I recently slid into a curb with my front drivers side tire of my 1992 Acura Legend. Now it is as if I have no power steering and the steering wheels just sticks in place. Any Ideas on just what this could...
  1. if there is a damage (bends) in the front (Rh or Lh side) stabilizer bar,it form a trust on wheels and does not allow to move.you feel heavy steering.
  2. rake might be bend resulting the rake bushes will not allows to move freely.
  3. castor bar damage will have the same effect.
  4. check all above and see
2helpful
2answers
Recently slid into a fence durring ice/snow storm.
I'd say the linkage is a little bit off and the shifter is not quite putting the linkage in the park position. To confirm this you might try pushing and or pulling on the shifter a little bit as you trying to start the vehicle.
Remove and replace passenger door mirror on 2009 ford explorer XLT, main part , I don't know how to remove the interior door panel. Pictures might help,
  1. Remove the front door trim panel handle bezel cover.
  1. Remove the front door trim panel handle bezel screws.
  1. Remove the front door trim panel lower screws.
NOTICE: To avoid damaging the front door trim panel, do not pull the bottom of the panel outward.
  1. Remove the front door trim panel by lifting upward on the armrest to disengage the panel clips.
  1. Disconnect the electrical connectors.
  1. Disconnect the lock rod cable from the front door trim panel.
  1. Disconnect the door handle conduit and cable from the front door trim panel.
  1. To install, reverse the removal procedure.
be patient during these procedures to not damage the trim panel...they cost $150>275 ec........GL hope this helps
1helpful
2answers
Trunk leak
Check for defective spot welds around the plastic inserts on the left and right sides of the trunk. If the spot welds burnt through the metal, there will be holes were water can get in. Use some JB Marine Weld to seal up any holes or cracks in the sheet metal. Also, check the rubber drain holes under those inserts, that are in the sheet metal of the car, to make sure they are not blocked with road dirt. Also, check the weather stripping on the outside of the car, adjacent to the trunk. If the rubber and chrome trim weather stripping is pulling out (on the exterior of the rear quarter panel), then water will leak through the little plastic attaching screws and into the trunk beneath the plastic containers on the left and right front sides of the trunk.
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
