Question about ASUS A7S8X-MX Motherboard
Dual display will i get signals from my on board and my video card at the same time if i enable the dual display support on my a7s8mx-mx motherboard? can i connect two monitor at the same time?
  • 50 Answers
On some bios's, you can turn on both your onboard video card and keep that enabled while using the other monitor. However i reccomond you buy a video card that supports a dual monitor system without need for tweaking. Otherwise the simple answer for your issue is no and will require much more work than a conventional dual monitor system.
Posted on Feb 24, 2008
Dual vga displays
With some motherboards the on board Video is automatically cancelled out when a slot dependent Video Controller is present. Bios will not change that option. If you want to use two Monitors at the same time, get a DUAL Video out card.
Jan 18, 2014 | AMD Athlon II X2 Dual-Core Processor 260...
I have an Asus P5GZ-MX mother board and all i get on screen is a message that says No Signal help Me
Your problem is with getting video from your graphics card. I would suggest you check your cables from your monitor side and then the cable that attaches to your video card one side or the other may not be connected tightly. Unplug them and replug them in make sure on both ends they are on tight and screwed down tightly. If they are both tight on both ends then the problem is with your video card. If its been working ok all along then it possibly may have failed and you may need to replace it.
I hope this helps you out and if it does please leave a Yes on the response that I have given you. Thank you.
Apr 08, 2011 | ASUS P5GZ-MX Motherboard
ASUS P5GC-MX/1333 Windows 7 32-bit How do i enable the on-board vga as well as a pci-e graphics adapter simultaneously?
this would be donne first in bios and secondly under display properties/settings in windows.  this is assumming that the onboard graphix is capable of multi-monitor arrangements.
Dec 28, 2009 | ASUS P5GC-MX/1333 Motherboard
PCI-E recognition issue on intial start up ASUS P5GC-MX/1333
To solve this problem you have to do the following things in the series.
first remove all the extra cards and then connect to the onboard vga connector. then start the sys and go to bios settings. if you know the advanced adjustments then
correct them as follows. otherwise just select load optimized settings.
first go to the video card selection in advanced
and then set the setting to pci/pciinternal or pciint/pci ext
then set the pallette snooping to yes.
shutdown system
place graphics card and then donot change any setting. then you'll get the display.
i have the same motherboard and i also faced this once. it is not a problem it is just misconfiguration.
Apr 21, 2009 | ASUS P5GC-MX/1333 Motherboard
Can not install built in audio
disable the old audio card in bios before attempting to install a new sound card.
Dec 24, 2008 | ASUS P4S800-MX Motherboard
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Dave
Nov 11, 2008 | ASUS M2N-MX Motherboard
Monitor doesnt switch on
Can you try another monitor?
Since you did try another video card (AGP). I posted (In you're other post), you have to make a bios adjustment under Advanced menu. Once you're P4SP-MX bios is set to boot to the AGP or set to Enable. The bios will no longer try to load the on-board VGA card. I am not being picky about the statement I am going to make ( so don't be offended). Monitor's only receive signal. They do not send signal to PC, just receive. The odds of two video cards not working is high. You did mention you have not heard P.O.S.T (A single beep), which is a test of the motherboard. There could be a loose connection in you're PC. I would remove the memory first. Clean the contacts with alcohol on a cotton swab & blow out the memory slots with canned air (allow time to dry). Than firmely reseat the memory. I would than re-check all data & power connectors within the PC, making sure all are securley connected. With respect to the AGP card, I would do the same. Remove, clean & reseat. Most older AGP's require additional power. Some use a power cable that is also used to power a floppy drive & others use a 4 pin molex (see link),
http://pinouts.ru/connector/4_pin_Molex_power_connector.shtml.
When you are in the bios & within the Advanced menu you may also need to set the bios to read you're AGP card to the correct speed. (EX: 1x,2x,4x). Page 2-19 in you're manual. Once all these checks & cleaning have been completed, try again. Boot the PC and hopefully you will see display on you're monitor.
Post here. Let me know how thing go. Don't assume anything, check all.
Luck!
Mike
May 12, 2008 | ASUS P4SP-MX Motherboard
Dual display support
nothing, you just get two display there.
Feb 24, 2008 | ASUS A7S8X-MX Motherboard
Asus P4P 800 motherboard no signal on monitor
Make sure that the right video source is selected in BIOS.
Nov 30, 2007 | ASUS P4P800-MX Motherboard
ASUS A7S8X-MX Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
