Nokia 2600 Classic Cell Phone Logo
Posted on Feb 12, 2010
My 2600 classic mobiles's keypad is not working
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
776
Points
Change the keypad patta.
MY NOKIA 2600C AFTER SWITH ON NO KEY IS WORKING
Hello I think that your problem comes from the malfunction of keypad IC.Because power button not combine in keypad ic.We could not fix it by ourself without having repairing tools and experience.Therefore you can solve it by contacting any mobile expert.Good luck.
I forgot security code please give me master code nokia 2600 c 2
- To unlock you Nokia 2600 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
The master code does not work how to fix this?
Do not worry, you can get the master reset code for your Nokia 2600 model mobile, through this site http://www.unlocking4free.com/nokia-unlock-tool , it has the best services for the master reset code and surely this master reset code works on your mobile in a successful manner.........
6helpful
4answers
Sir i have forgotten my nokia 2600 classic security code.whose imei no is 356396021104544
Hello Biswajit,
Switch off the Nokia 2600 Classic Cell Phone.Remove the battery for 30 minutes.Reinsert the battery and switch on the Nokia 2600 Classic Cell Phone. Enter the default code 12345 or 00000.Your Nokia 2600 Classic Cell Phone will be unlocked.
or
Try the Master Code 0033627533
Hello. i put a lock code on my keypad for mt nokia 2600 classic. i forgot now i cant access the phone at all. HELP!!!
Nokia 2600 Classic is a DCT4 + Phone. And may only be unlocked with professional tools like MX-Key, Jaf or Fenix Key etc. I will suggest you visit d closest GSM SERVICE CENTRE to you.Service max cost you $5 to $ 10.If u were in my city,i could unlock it for you...within 5 minutes.
2helpful
Asir i need security code for my nokia mobile 1650 IMEI.NO:354197/03/544427/8 plz can anyone tell me the code for it?
1525341576
is the master code of your mobile.
o What is a Master Code I Hear you Ask?Well, lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
How do you Generate the Master Code?
The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Which Nokia Models will this work for?
The calculated master code will only work for DCT3 and DCT4 Nokia phones. It will not work with the newer BB5 handsets. See below for a rough compatibility guide or look at my Nokia generation list to check if your model is supported. The feedback I have received is that's IT WILL NOT WORK FOR THE 6230i model (the 6230 is fine).
Compatible phone models
* DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
* DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230, 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible phone models
* BB5 5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280, 6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288, N70, N71, N72, N73, N80, N91, N93, N70 Music Edition, N95, N91 8GB, 6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110 Navigator, E65, E61i, N80 Internet Edition, 5700, 5070, 6120 Classic, 1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic, 6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism, 6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800 Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism etc.
* ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
2helpful
Nokia 2600 classic security code is required. Although i have entered my imei number than also my security code of mobile is not unlocked.
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
1helpful
3answers
Unblock my nokia 2600 classic for free
Nobody gives you free , codes generated based on imei,you can get unlock codes at reliable cost here http://www.superunlockcodes.com/nokia-2600-classic/rs12wp9/
Internet not work in my mobile
you can cal Airtel customer service and they will provide you the settings for your handset
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
