Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool range RDE 6100N2
I had this bright idea to really clean the old range that came in the house that I bought years ago. It looks like new now, but I can't get the oven door back on. I have tried for two days now. Can you help??
  • 1 more comment
  • CKWCON Feb 24, 2008
    We needed to change the element in the oven and lost the wire inside
    the unit. Then we had to take the entire stove apart and found
    out how to get to the wire. Once completed, we tried to put the
    oven door back on to no avail. It came right off initially.
    Thank you! Thank you! Thank you!! It just went back on!!!!1
  • Ron Coons
    Ron Coons May 11, 2010
    how did youget it off? did it lift right off oryou had to fanagle it a bit??
Instead of trying to place the bracket to the door from a lowered position at floor level, I positioned the brackets and from a standing position, placed the bracket into the slot, pushed in a downward position and the door went into place.
Posted on Feb 25, 2008
Range throws an F5E1 code, cleaned the oven 2 weeks ago. Worked fine. Plugged it back in today to clean oven but it threw the code, door is not locked.this is in a rent house.
Using the 'self clean' function nearly always results in faults. We see it here all the time, burnt out elements, doors that won't open, fires and error codes. Google the manual for it. They are all online
make model manual
The error is listed in this link. Also look at the video tab
whirlpool f5e1 error code Google Search
Door latch problem
Whirlpool Super Capacity 465 E1 F5
Apr 09, 2018 | Ovens
I have a wall oven that is 15 years old and it's making a loud noise, after it's turned off. This has never happened before.
Don't burn your house down! Get a new wall oven. FYI Sears no longer sells Whirlpool.
Nov 10, 2017 | Whirlpool Ovens
I have a Whirlpool Super Capacity 465 gas range. I have no idea how old it is. The oven door refuses to open. I did use the auto clean feature about a week ago and have used the oven since with no problems...
Hello & Welcome to FixYa
The problem is with the door lock assembly that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Sep 12, 2011 | Whirlpool Ovens
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
No manual to Kenmore electric oven 8+ years old
if the glass bulb cover has a 'wire' across it that's the spring clip that holds it in place.pull clip down or aside to remove cover,unscrew bulb as you would any other.if it doesn't have aforementioned clip.try to rotate cover counterclockwise to disengage 'ears' from 'slots',similar to the the way a blender fits the base.look under cook-top,above oven door for the lock lever that must be pulled out [engaged] for self clean to work.
Oct 11, 2009 | Kenmore Ovens
Oven too hot!!
sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RBS275PD Electric Single Oven Logo
114 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
