Question about Sony SDM-HS73P 17" LCD Monitor
Works when it wants to then turns whie with grey line in it
My monitor goes into a permanent sllep
    Scholar:
  • 80 Answers
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Posted on Feb 25, 2008
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Jun 11, 2009 | ViewSonic VA721 17" LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Sony Laptop Screen goes Grey
1.What I need you to test is...When laptop monitor go grey try plug external monitor and see that it work fine or not ??
2.Incase it work fine try to give a little tap behinde the laptop monitor and see that any changes...keep try and harder and see
3.Incase if you gave a hard tap also and its still the same but external monitor work fine then....I think you have problem with your LCD monitor coz there are chips that control the LCD crystal and maybe when it goes hot it behave this way....in this case you can't change the chip...you have to change the LCD.
takecare.
Jul 18, 2008 | Sony VAIO VGN-FS640W Notebook
Missing keystrokes while typing quickly
Read another post like this, and it turned out to be a short in the laptops battery.
Jul 01, 2008 | Avocent SwitchView 1000 KVM Switch
Kepps going to sleep
your setting in the screen saver has been set to shut down go to control panel then appearances and theme select screen saver you shoul see where the computer is set you can change it
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes grey.
It sounds like you have a faulty plug. Here are some things to look for Look in the plug itself for bent or (this ones the biggie) Pins that have been pushed in to the plug, Make sure they all line up evenly. On some monitors there is a setting for "Degausing" try that one. If you are plugged into a External video card meaning one that is not attached directly to the motherboard, Open the computer and make sure the card is seated properly. If it is a plug that is directly on the motherboard check to see if there are dust bunnies or dirt around the socket. A lot of household lint and dirt have metallic salts and can cause problems. Clean it only with aerosal air and nothing with any liquid cleaner. Good luck... Be mucho blessed...Mark
Jun 26, 2008 | Dell Dimension 4700 PC Desktop
Green line
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you.
Mar 10, 2008 | Acer AL2216WBD LCD Monitor
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
448 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
