Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Only want grayscale or non color as my default printing
I have a Brother MFC 240C all in one printer. Most printing jobs I only want black print not the color. One time and one time only I found a way to get rid of the color and I thought I had made this my default printing, but the next time I printed something I got all the unnecessary color with it. Help please Z. PERLINN
  • 832 Answers
You have to change the printer settings to greyscale (2. chapter of the settings) each time you run a b/w print.
See here what you have to do, too:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002000/000015/faq002015_001.html?reg=us&c=us&lang=en&prod=mfc240c_all&Cat=3
Posted on Feb 24, 2008
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
My printer reverts to color print settings after setting to grayscale in properties (and yes, I clicked apply before closing and I am making these changes through the control panel). Setting the default to...
yes, when you print on Windows operating system in any word form program such as word, acrobat reader, and or any internet browser, if you press control and p st the same time the printing preferences menu will come up change your preferences as needed there hit apply and that's it let me know if that doesn't work
May 11, 2011 | Brother Multi-Function Center MFC-240C...
I just changed my ink cartridges but now the printer is only printing black and white
STEP 1: OPEN THE PRINTER PROPERTIES:
WINDOWS 98/ME/2000
A. Click on START -> SETTINGS -> PRINTERS
B. Right click on your Brother machine (example MFC-XXXX where X = modelnumber of your machine) and left click on PROPERTIES
WINDOWS XP
A. Click on START -> CONTROL PANEL -> PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE, then PRINTERS AND FAXES)
B. Right click on Brother machine (example MFC-XXXX where X = model number of your machine) and left click on PROPERTIES.
WINDOWS VISTA
STEP 2: CONFIGURE THE PRINTING PREFERENCES
Depending on which version of the driver you are using, you will need tocomplete one of the following sets of steps.
A. If using the Brother Original Driver:
i. On the GENERAL TAB click the button for PRINTING PREFERENCES.
ii. Click the ADVANCED TAB.
iii.. Choose COLOR
iv. Click APPLY -> OK
v. Click OK to close the Printer Properties window. Your printer will now print in grayscale.
B. If using the Vista built in Driver:
ii. Click the PAPER/QUALITY TAB.
iii. Choose COLOR
Oct 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brothers MFC-240C not printing in color???
Do you have it set to print in black and white as the default? Go into the print driver, under Color Management, and select Color.
May 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Does not print in color
Without knowing anything more about your problem, it sounds like you have the print driver defaulted to print in black and white only. To print in color, go into the print properties of the program you are printing from (in Microsoft Word, for example, click File > Print, and then Properties), then go to the Advanced tab and where it says "Color/Grayscale" select Color. Click OK and then print your document, and it should come out in color.
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
Trying to print from microsoft word . Keeps printing in black. Color cartriges 75% full. What am I doing wrong?
  • Go through the Print menu (from Microsoft Word)
  • On the Print Dialog screen, select Properties
  • Click on the Color Tab
  • Make sure Color button is selected (not Black or Grayscale)
  • Press OK
When color is selected, the printer will print Black as well.
If Black is selected. the printer will not print color.
Hope this will work for you.
If this answer is helpful, please give a rating.
luciana44
Dec 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Won't print in color
Make sure you run the cleaning mode under the INK button. Run it 2-3 times to get the ink through the tubes. If you are using generic ink, it may have clogged the tubes in side the unit.
Jul 14, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
191 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
