Question about Epson Stylus CX6600 All-In-One InkJet Printer
I can't upload pictures!
When I put my SD card into the slot the little screen says "Found images...Total 49 OK" but when I press the OK button, nothing happens. It used to work just fine, but for some reason it won't now. What can I do to fix this?
  • Anonymous Mar 05, 2008
    When I put an sd card in I get abslutely no response
  • 59 Answers
Not sure if this will work, but in XP, double click my computer. The SD card should show as a removable drive. Double click that. The pictures should be there. Now all you need to do is drag and drop the pictures wherever you want them to be saved at in your computer
Posted on Mar 11, 2008
Purchased soft wear upgrade for kenwood DNX8220BT from garmin when it arrived it is an SD card, how do I upload the information to my kenwood navigation system?
Press and hold the eject button for a few seconds. The screen will lower to reveal the SD slot. Put the card in and follow instructions when prompted.
You do not need to leave the card in.
Aug 20, 2013 | Kenwood KVT-512 Car DVD Player
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
How do i transfer pictures on a samsug sch i760 onto the micro sd card?
    The microSD memory card MUST first be formatted, by the handset, in order for the handset to create the destination folders.
    To transfer the pictures, remove the memory card slot cover. Insert the microSD card into the slot until it locks into place. Press the OK key for menu. Select Get it Now. Select Picture and Video. Select My Pictures. Select desired picture. Press the right soft key for options. Highlight move and press OK. This puts the picture on the SD card.
Oct 22, 2010 | Samsung SCH-i760 Smartphone
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
My camera stopped uploading photos
If the camera still works OK otherwise -- you caN BYPASS THE PROBLEM with coimputer recognition simply by removing the SD card, and reading it directly. Most notebooks have a slot for plugging in an SD card. Otherwise -- there are some very cheap SD card readers (<$5.00) -- insert your card, plug into USB Port, then (on Windows) select "Open Windows Explorer" select and copy your digital images to your PC.
Feb 26, 2009 | Pentax Optio 60 Digital Camera
Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
Feb 14, 2009 | Kodak EasyShare C330 Digital Camera
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
Jan 13, 2008 | Pentax Optio S6 Digital Camera
Upload images to SD card
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
I'm experiencing the same problem. The only solution I've found so far is to just get a digital card reader that plugs into the USB port of the computer.
Dec 15, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
