Question about Goodman GMS90703BXA Heater
Goodman Heater Without a pilot light how do I get heater to heat? there is no pilit light, don't understand.
  • Anonymous Feb 25, 2008
    my valcun ducted heater is not working although the fan is going and checked the power switch is on. what could be the problem
  • 1,420 Answers
This furnace has a diagnostic light on the control board found in the lower section of the furnace. Pilots are a thing of the past and your system has a glow ignitor. Look thru a small viewing port to see how many blinks are being displayed. Then remove the access panel and on the reverse side of it is a diagnostic chart that will tell you where to start looking. I would suggest you make sure the air filter is clean and that the condensation is being removed. Recycle the furnace with either the breaker or emergency switch. You can cycle the furnace with the front cover off if you tape the door switch closed. It may be easier to view the sequence of operation to pick up on where the fault is occuring.
Posted on Feb 25, 2008
Goodman gmt070-4a wont heat, like the pilot light is out or something
turn gas supply on....turn gas valve to pilot....press down and hold to allow gas to come through pilot tubing.....light the pilot right by the thermal couple, once lit hold valve down for about 60-90 secs...then release ur hand on the gas valve and turn the valve to on position............make sure the bloody tstat is turned off before doin anything other wise burners will fire up soon as you turn valve to on position
Dec 05, 2013 | Goodman GMS90703BXA Heater
Pilot won't stay lit on mr heater vent-free propane heater
if it is direct vent chances are it has electronic pilot.. it does not have a standing pilo and match size upt. if in fact it did have a buning pilot there is a part called thermocoupling. it will look like a 1/8 in. copper wire coming out of the bottom of the gas valve and goes right to the pilot. anywhere from 10 in. to 20in.. unscreew nut at gas valve pull out from pilot area [ it just clips in at pilot] take it to any home center
Nov 25, 2012 | Kitchen Ranges
How do I access pilot to turn on heater?
A GMS Goodman furnace does not have a pilot light. It is electronic ignition.
Nov 29, 2010 | Goodman GMS90703BXA Heater
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
Goodman ez 1425 blower works but no heat
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Feb 21, 2009 | Goodman GMS90703BXA Heater
Why the Goodman air heat unit that will not come on?
we are trying to loacte teh starter for the pilot. Seems to kick on but no hot air, so not heat throughout the house. Sorry, total mentally challenged in basic home appliance repair...
Jan 27, 2009 | Goodman GMS90703BXA Heater
The heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Jan 16, 2009 | Desa International CBN20T Heater
How do I light the pilot light on my older Goodman heating and air unit?
depending on how old the unit is , you turn the gas valve to pilot setting, hold down the button, light and hold for 1 min.
Oct 27, 2008 | Goodman GMS90703BXA Heater
Pilot on but no heat to radiators
There is a gas valve inside the heater (is it on?), There is also sometimes an electric starter that goes bright on start (is it?), Do you hear whirring noises on start? Is the valve switch set to ON?
I have one of these and if the pilot (electrical) turns on and the gas is not flowing then is senses a heat failure and stops. Then on the control board light blinks (seen through plastic cover).
These also have to spin an exhaust fan, that bearing sticks, if it fails to turn, the unit will fail to start after 1 min. Does any of that makes sense?
Nov 10, 2007 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
150 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
