Question about Ovens
Replacement of bottom oven element for Whirlpool oven
We have the replacement element but we can't get the old element out. Husband is an electrician.
  • 3 more comments
  • TQ27 Feb 26, 2008
    Hidden element. We gotit out using brute force, it had broken in two pieces and was getting caught on the way out. This is a European oven by the way, and the element comes out the back. I got it out in the end, hubby then fixed the oven all going well now. Thanks for the reply.
  • Anonymous Mar 14, 2014
    how do I replace the bottom element of oven?
    How do I disconnect the two wires from the bottom element of oven to replace the element?
  • Anonymous Mar 20, 2014
    Cannot find contacts at back of oven when replacing broiler element.
  • Anonymous Apr 01, 2014
    how do I replace a oven element receptacle
    President:
  • 2,651 Answers
Its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Posted on Feb 24, 2008
Top Oven overheating already replaced sensor.
have an electrician check the element wiring as it should only get red when on full heat but then be controlled by the thermostat
it appears that the element is bypassed the thermostat or the thermostat is failed
for the bottom not to get red is a further indication of incorrect wiring of the elements
Nov 16, 2015 | Maytag MEW5630DDB Oven
I have a Whirlpool Envoy Oven that now needs a replacement oven element and guard for it. I don't have a product or model number for it. I just know the oven is at least 30 years old or more. I'm having...
Hello, I'm not a salesman, I really do try my best to help people. I would suggest replacing the Oven, not just the part on a machine of that age. I hope that was a help?
Oct 02, 2013 | Whirlpool Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
Sep 17, 2007 | Whirlpool Ovens
Ovens Logo
523 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
