Just disable the pop up message
Printer does not stop printing
You cannot reset the ink levels for the HP 901 (or 901XL black) cartridges - ink monitoring is used for planning purposes only and does not interfere with regular printing ops. Just ignore (dismiss/OK/continue) any warning or alert messages that gets displayed. Here are some helpful videos specific to the OJ J4500, J4600 and 4500 printer series, including fatal cartridge error bypass procedures and cartridge electrical health check test patterns (which are useful at validating whether an HP 901 cartridge is defective or not): HP Low Ink Warnings (HP Integrated Printhead Cartridges): HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4 HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE (please note this is a service test, the printer will attempt to print the tap 41 pattern, whether the cartridges are good or bad):
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know:http://www.youtube.com/watch?v=jTtNj6rN4g4
You cannot reset the ink levels for the HP 901 (or 901XL black) cartridges - ink monitoring is used for planning purposes only and does not interfere with regular printing ops. Just ignore (dismiss/OK/continue) any warning or alert messages that gets displayed. Here are some helpful videos specific to the OJ J4500, J4600 and 4500 printer series, including fatal cartridge error bypass procedures and cartridge electrical health check test patterns (which are useful at validating whether an HP 901 cartridge is defective or not): HP Low Ink Warnings (HP Integrated Printhead Cartridges): HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdR... HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQ... (please note this is a service test, the printer will attempt to print the tap 41 pattern, whether the cartridges are good or bad):
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know:http://www.youtube.com/watch?v=jTtNj6rN4...
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP
integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901,
92-98....currently offered at Costco or Frys today) or if you buy a
remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP
has a smart chip embedded within the nozzle plate at base of ink cartridge
which counts the drops and then registers as empty).....so you'll just need to
live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and
similar while you are using these types of aftermarket supplies. The first
video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below:
Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
When you get an HP
remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
Low Ink Warnings:
HP Officejet J4500
HP
901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
