LG 22LS4D - mac connection
I have just bought the LG 22LS4D to use as a 2nd monitor for my macbook and as a tv for my PS3, I have a mini-dvi to VGA adaptor and have input a VGA cable to the screen and it says 'no signal', although my mac recognises the screen is there.
Any ideas!??!
Yer i got that problem 2.
Posted on Jun 06, 2008
Would appreciate any advice on connecting cable etc. to connect my Compter and TV to display video/film downloads.s
The easiest connection is converting to VGA and using a standard headphone port-to-audio in. Your video out from the laptop varies by model, which isn't included here.
It will most likely be mini-VGA or mini-DVI
Nov 04, 2012 | Computers & Internet
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Trouble connecting Insignia HDTV 19" to my macbook pro
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
Macbook - Lg TV
Take a look at these discussions:
http://macosx.com/forums/hardware-peripherals/304718-connecting-macbook-lg-hdtv-rz-32lz55.html
http://discussions.apple.com/thread.jspa?threadID=1398546
Maybe a solution.
Good luck.
K.
Jan 04, 2010 | Apple MacBook Mac Notebook
Connecting LE26R8 to MacBook Pro
Hi.
LE26R8 its a Samsung LCD TV.
You can Connect a LCD TV to MacBook Pro.
You need a mini dvi to dvi or mini dvi to vga depending on your monitor. You also need a cable to get the sound to the tv from the macbook (from headphone output specifically)
Also Watch this video its a Tutorial to How Connect a LCD TV to MacBook Pro.
The Video:
(do not delete)
Good Luck.
Nov 03, 2009 | Samsung Audio Players & Recorders
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
