Question about Baby Gear
Seat stuck on base
My infant car seat is stuck on the base. When I lift the lever that is supposed to release the car seat it doesn't come off. Any idea how to fix this? I have other Peg Perego seats and have never come across this. Thanks!
  • 1 more comment
  • djy1975 Apr 05, 2008
    Hi there, I have the same problem as the other person did with not being able to get the car seat off the base. (I have a Graco Snugride Milan). The car seat seems to be stuck on the base. When I lift the red lever, it will lift on that side but it appears to be stuck in the front I believe....any suggestions?
  • Anonymous Nov 10, 2008
    I have a snug ride car seat and it gets stuck in the base all the time!!!
  • elubos Mar 24, 2009
    Hi, i have Graco child seat, just got it from friends. Th eseat is stuck to teh base, and I can;t take it out? Can anyone help, please?
  • 2,039 Answers
There something that fell in the locking wiggle the seat while trying to unlock it there no miracle there dont forse it but pierre
Posted on Feb 24, 2008
My car seat is stuck in the base
Push down hard on the seat, then pull the release.
Jul 07, 2014 | Maxi-Cosi Maxi Cosi Prezi Infant Car Seat...
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
Carseat jammed to easy base 2
Try pressing down very hard on the seat while trying the release. If that does not work, call the manufacturer.
Note: if this does release, check the seat belt for damage before using again. Also check that the belt path used to install the base is/was correct.
-- Marc
May 23, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Car seat stuck in base. The back comes loose but the front is holding on help
there might be a release button in the front of the car seat right around were your childs legs are, it maybe red in coulor, push that button it may release the front
Sep 20, 2012 | Graco Snugride - Family Tree Infant Car...
My cabriofix is stuck to the easybase 2. The handle does not seem to work. Do you have any ideas?
The handle is not any part of removing the CabrioFix from the Easybase 2 apart from to lift the carseat away from the base. You need to press the grey / silver buttons on either side of the carseat and hold them down as you lift the carseat from the base to remove it.
If you're still unable to do so we would advise you to take the product to your retailer with proof of purchase for them to investigate further.
Aug 07, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
Pt cruiser stuck middle seat belt
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism lock as it should when not level. So the seat cannot be raised up as the belt is too tight and locked.
The Solution:
1) Push the two little clips to release and remove the headrests.
Pull the grey lever on the right of the seat base, lift seat base up and forward toward the front seat..
2) See two red capped leversat the back of the two seat hinges and lever them to the upward position, this releases the seat.
Rock the very heavy seat unit upwards and lift complete unit upwards.
3) Take it out of the car and turn 180% so that the back of the seat and base are in the upward position and the seat belt will pull out as it should
4) Replace the missing belt locking stop (I used a tie pin permanently fixed using super glue).
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption..
Aug 02, 2012 | Chrysler PT Cruiser Cars & Trucks
I washed my daughters graco car seat and now i havent a clue of how to put it back together and i need re assemble it fast please help
Proper installation of a car seat is imperative to protectan infant. Accidents do happen and assuring that the instructions forinstallation of the Graco Infant Restraint/Carrier are followed will increasethe chances of preventing injury or death as a result of an accident. Graco carseats are a popular choice among parents due the availability of products atcommon retail stores, affordability and user-friendly baby gear.Graco Car SeatInstallation
Step 1
Plan to secure the infant seat facing the rear inthe middle of the back seat. If a center position is not available, positionthe seat directly behind the driver's side seat. For safety reasons, therestraint should not be placed in a position where there is an air bag. Ensurethat the proper vehicle lap belt system is in place; manually adjusted lapbelts, automatic locking retractor lap belts and lap/shoulder belts withlocking latch plates are all considered safe for use with the Graco InfantCarrier/Restraint.Step 2
Remove the carrier from the Graco car seat baseby squeezing the lever at the rear of the restraint and lifting the seat up.Place the base in the vehicle facing the rear. Thread the vehicle shoulder andlap belts through openings at the end of the base without twisting the belts.Secure the belts by placing plastic tongue over the belts. Tighten the vehiclebelts by pushing down on the base and pulling out any slack.Step 3Install locking clip to secure shoulder and lapbelt together just above the seat belt buckle. Connect the two belts with thelocking clip. Buckle the lap belt system and tighten by pulling out any slack.Ensure that car seat base is secure by pulling and pushing on it; the baseshould not move sideways, forward or backward.Step 4
Place the Graco carrier in the base. Push down onthe restraint until it clicks and locks into the base. Set the infant in therestraint for travel and place harness straps over the baby's shoulders. Clickthe chest place together over the sternum and lock the buckles into placebetween the legs.Tipsand Warnings
  • Contact local police departments, hospitals and fire departments to inquire about child car seat safety checks
  • Graco Infant Restraint/Carrier will not protect against serious injury or death if not installed properly. Always read the Graco owner's manual that comes with product prior to attempting installation and travel with an infant.
Jul 19, 2011 | Home
Handle is stuck in the carry position--Can it be fixed?
These car seats seem to have a problem in the release mechanism that
lets the handle move. We have found that lifting the handle a bit as you press
the releases can help. Try pulling toward the front of the car seat, then pressing
the release buttons. If all else fails, call Baby Trend and complain. It just might
get you a replacement if you can prove it is a danger to the child in the seat.
Baby Trend, Inc.,
1607 S. Campus Avenue, Ontario, CA 91761
By Phone: 1-800-328-7363
Mar 26, 2011 | Baby Trend Flex-Loc Infant Car Seat -...
We have a cabriofix car seat on a family fix base (purchased new in Dec 2010). The car seat is stuck on the base. One of the clips will not release when the grey handle is pulled. Any ideas why?
Get back to where you bought it for a replacement - these things HAVE to work perfectly to keep your child safe - don't try to "fix" it you could live to regret it.
PLAY SAFE
Mar 13, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Baby Gear Logo
1,454 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
