Question about Webroot Spy Sweeper (spysweeper) for PC
SPY SWEEPER I KEEP ON GETTING A MESSAGE THAT SAYS WEB ROOT HAS EXPIRED. NEVER HAD ANY PROBLEM UNTIL A FEW WEEKS AGO THANK YOU
    Scholar:
  • 117 Answers
Are you running Windows Xp or Windows Vista
That error on XP usually means that your trial version or full version has expired. If you have upgraded to Vista, then you will need to uninstall Spy Sweeper and reinstall.
If you do not have the option of purchasing the software, then go to this link for a few version
http://www.computeractive.co.uk/spysweeper/
Posted on Feb 24, 2008
Can not update update is set to automatic but gives fault
Could Spy Sweeper be corrupted with something?
Subscription expired?
Your firewall might be blocking it.
Try going to the program controls in the settings of the firewall and removing it from the list.
Post your answers as a comment and I'll be notified
let me know if this help please
Thank you
Feb 01, 2011 | Webroot Spy Sweeper (spysweeper) for PC
I keep getting the message "The spy sweeper installation has been damaged. Please reinstall the product. (105) Can you help?
get rid of spy sweeper and get a program call deep freeze there is a trail version here http://www.faronics.com/html/deepfreeze.asp this application will also let you get rid of your antivirus program, you see antivirus program's can only protect you from what allready is and not what s comming. with this program you get a virus simply turn off and on the computer and wala virus gone.
Sep 28, 2009 | Webroot Spy Sweeper (spysweeper) for PC
I have weebroot cant sweep
There is a serious problem with spy sweeper webroot V 6.0. If that’s what you are using, uninstall it and use V 5.5 instead until they fix the problem.
I hope this helps
Jul 19, 2009 | Microsoft Windows Vista Home Basic Edition
Spysweeper does not work when you click on it
Web Root Spy Sweeper is an adware itself, this program install a key in the startupregistry with the name spy falcon, making you beleive that is a realadware .Sweeper auto quarantined some files need by the operating system............a better alternative is spyware terminator (click here) and is complete freeware8523dbf.jpg
Jan 03, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Previously owned Webroot Spy Sweeper
It doesn't really matter which version of Spy Sweeper is on the installation disk, as long as the subscription associated with its product key hasn't expired. Spy Sweeper will immediately update to the current version after you install it.
The clock starts on your one-year subscription when you enter the product key during installation. If it's a 3-machine license, then the clock starts on all 3 copies when the first one is installed.
Dec 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Uninstall
use Ccleaner software to remove spysweeper software. link is below.
http://www.ccleaner.com/
May 29, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy sweeper not working
1- Install using this serial: SSDC-ONLN-AAAA-NNNL-NINC
Then
2- Go into the C:\Program Files\Webroot\Spy Sweeper
Then
3- Right click the "install.dat" file-->go to Properties--> at the bottom check the boxes "read-only" and "hidden"-->then click Apply
And finally....
4- Run SpySweeperFix.v1.1.exe
Allow SpySweeperFix.v1.1.exe to run on the next Windows start up, this gives you the definition update till 2020, otherwise, you'll just get till 2006!
Hope this helps, if not, post back.
May 23, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy problems
First Try This:
Try to uninstall Spysweeper and reinstall (Control Panel -> Add Remove Programs)
If it gets nasty reboot in to safe mode (follow these steps):
1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the "Windows XP with networking"
Once you are in safe mode do this:
1. Download the free microsoft app "Autoruns" from http://download.sysinternals.com/Files/Autoruns.zip
2. Extract the .zip file
3. double click the file "autoruns.exe"
4. The program will start autoscanning your computer to see what boots up with it (it will take a few min.... bottom left of screen tells you when it is done)
5. Make sure you are in the "Everything" tab (which loads up by default)
6. Hit CTRL + F (to do a Find)
7. Type "Spy" and hit ENTER
8. The first entry containing the word "Spy" in your startup instructions will be highlighted
9. Look at the "Image Path" column, if it contains anything like "C:\Program Files\Webroot\Spy Sweeper\" uncheck that item
10. Press F3 to see the next item containing the word "Spy"
11. Keep repeating steps 9 & 10 until you get through the entire list
I'm guessing you might find the following:
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
12. Reboot as normal (spysweeper should not load up)
13. Attempt uninstall, reinstall again
Jan 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot Spy Sweeper (spysweeper) for PC Logo
83 people viewed this question
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
