Question about Samsung Cameras
SAMSUNG D85 SHORT BATTERY LIFE
MY D85 IS ONLY GIVING ME 10-15 PICTURES NEW BATTERIES THE CAMERA IS ONLY 4MONTHS OLD IT NOW FAILS TO TURN ON AT ALL THE GREEN LIGHT COMES ON BRIEFLY THEN GOES OUT...
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
  • 2976 Answers
SOURCE: camera wont turn on batteries are new
If your batteries are new, they could also be dead or too low. If they are rechargeable, give them a full 12-16 hour charge before using the camera. Rechargeable batteries have a lower voltage than regular batteries.
Posted on Jan 02, 2009
  • 6 Answers
SOURCE: my samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Posted on Feb 24, 2009
t00nz
  • 4738 Answers
SOURCE: Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Posted on Jul 21, 2009
  • 11967 Answers
SOURCE: my samsung s1065 camera has frozen, new batteries
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 08, 2010
2yrs old. Went thru 3 sets of batteries to get 20 pictures. Dead again. What`s the story?
Sounds like you have a short in the wiring. This is repair shop stuff, or buy a new camera time. Usually, if it is a point and shoot , it is not worth sending for repair as you'll playas much as a new camera is worth. I would look for a new camera, personally. Good luck.
Oct 20, 2014 | Cameras
Camera retracts it's lens and turns itself off about 10 seconds after I turn it on
Have you fully charged the battery? if it is a new camera or battery,it needs at least 12 hrs of charge,to maintain good charge, if only a short time of charge was given from new the life of the battery will be greatly re-juiced,try a new battery with a full charge, if this fails your camera is probably faulty, take it back to get a replacement.
Sep 07, 2014 | Olympus FE-210 Digital Camera
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Finepix e550 about 6 years old - brilliant camera and much used. Problem now arisen . New batteries inserted. Works perfectly but after about two days fails to take new pictures though all other functions...
YES HAD THE SAME PROBLEM..DIRTY BATTERY TERMINALS..SCRAPE WITH A FLAT BLADE SCREWDRIVER..LIGHTLY JUST ONCE..? POLISH BATTERY TERMINALS..A LIGHT RUB..SHOULD KICK INTO LIFE..DO THIS EVERY TIME NEW BATTERIES FITTED..HOPE THIS HELPS..P.S. THESE CAMERAS LOVE GOOD QUALITY FULLY CHARGED BATTERIES..NOT CHEAP ONES.???
Feb 03, 2011 | Fuji FinePix E550 Digital Camera
Camera was working fine, but suddenly battery life is short
dang I thought it was just me. I put so many brand new batteries in the camera,all kinds, no matter what it completely dead in about 2 minutes.. its frustrating b/c I got the camera last year as a xmas gift, so I really thought I was just an idiot when it came to operating the camera.. glad to know its just a crappy product; I still don't have a resolution though... sorry
Jan 01, 2010 | Samsung Digimax S730 Digital Camera
I try to turn on my camera and the lens comes out but then goes right back in and beeps as if the batteries are low but I know they aren't. I can still view the pictures I have already taken by pressing...
hi
i know its sounds odd but yes the charge on the batteries (Voltage/Amps) is falling short for the camera to start as it takes more power to run the camera than to just preview your pictures
one suggestion i can give here is
(this could be potentially hezardous so tread caution)
if you have rechargale batts then try electro jump to them take any source which is roughly 2-3times the voltage of the batteries (eg: if the batt voltage is 1.25 volts take a 3-5volts source) and connect the +ve wire to the +ve and -ve wire to the -ve of the battery and hold for 10 to 15 secs and then immediatly place it for charging and let them fill charge and use them till the batteries are completely drained
repeat this cycle for 2 -3 times and batteries will come back to life
be careful to connect the wires correctly else they might destroy the batts also not to hold for more than 10-15 secs
cheers
pls rate if this was any help
Jul 06, 2009 | Samsung SL310W Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Cameras Logo
74 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
