Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Maxtor OneTouch III 500gb
My Maxtor won't power up. The power supply's green LED is solid when I disconnect from the drive but when I plug it into the drive it blinks. I have plugged it into another Maxtor drive and it stays solid and powers up the drive. What does the blinking LED mean... is there some sort of short or something in the Drive??? Can this be fixed??? Please respond
  • CJSalsa Mar 21, 2008
    I have the same problem with my One Touch III.
    Is this just a problem with the enclosure, or with the internal IDE HDD?
    Do you think I can get the data off it by taking it out of the enclosure and connecting it directly to my IDE cable inside the PC?
    Problem Solver:
  • 5 Answers
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Posted on Feb 25, 2008
I need driver for maxtor onetouch III
Probably more than just a driver, but Maxtor is part of Seagate, so you should be able to find driver on Seagate's website. I had a 500gb Seagate that failed within the warranty. I didn't want to send it in with loss of all data, so I took it apart. Wala, drive was ok, the interface had failed. If the driver doesn't help Good chance power supply or interface is the problem and drive is ok.
Feb 27, 2015 | Maxtor 160GB OneTouch III Mini USB 2.0...
My maxtor one touch is not found on my white macbook
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
Mar 16, 2011 | Maxtor OneTouch III Mini Edition 120GB...
My Maxtor one touch has stopped being picked up by my computer when plugged in. When power source is plugged in led light (white) just blinks and never turns solid
You said it has stopped being picked up when plugged in so I hope this is note is relevantbut I don't think it is abnormal for it just to blink.
If the OneTouch does not appear in My Computer or cannot befound by Maxtor Manager, right click on My Computer icon and select Properties,Device Manager, Disc drives, and expand Disc Drives.
There may be ayellow overlay over Maxtor drive, to show it has a problem, so right click onit and select 'Choose drivers for this device' to reinstall them.
Without goingonline they seem to be found and reinstalled from somewhere locally on the PC and I hope this willdo the trick.
Also in case this helps, I don't find the OneTouch (Maxtor Manager) software appears when the driveis plugged in, so I think this is normal too.
You should look for an icon (a capital M within a blue disc) for Maxtor Managerin the taskbar, at the bottom right of the PC's screen.
Right clicking on this icon, (capital M), should bring up awindow with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Dec 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor one touch 4 plus will not power on even after replacing power supply
Have you tried it in different outlets? Is it also connected to your computer via the USB cable while it is plugged in?
Aug 27, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor OneTouch III, USB 2.0 (500GB) not found
yes someone can get the information off the drive it will cost but yes it all depends how much you value the information thats on the drive that you would want to do this it could just be the controler card on the drive or the onetouch's controler went bad if you know someone who can open the unit up for you (maxtor is no longer anyway) have then open the case and plug it into your computer and see if it will work as a internal drive
Feb 07, 2010 | Computers & Internet
Power supply problem used a replacement.it would light up for a second and pop. can i replace something drive s/b fine just need powering up. currently on 220v 50cy.
the drive inside is a standard hard drive, you may be able to plug it into a computer to get the data off it. i would contact maxtor for a replacement unit.
Sep 23, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Onetouch 500GB went dead
if there is warranty take it back to the shop you bought it from.
Dec 31, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Sortware for maxtor onetouch 111 mini edition to install in the maxtor onetouch 111 mini edition not compatible with MS vista ultimate 64bits
Here is the link to download the software for the Maxtor Onetouch III
OneTouch III USB
OneTouch III FireWire 400/USB (all models other than ones starting with FA)
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-maxbu-vista&vgnextoid=c42f69a859d63110VgnVCM100000f5ee0a0aRCRD
Or
OneTouch III FireWire 800
OneTouch III Turbo
OneTouch III FireWire 400/USB models starting with FA
Use this :
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
204 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
