Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Green is tilted
I have a jvc 56in.rear projection tv.
At first the green was rolled at the top left and bottom right.some one told me the green gun was bad so I bought one and put it in.and of course that dident fix it.after a little research I found out it was the convergence chips.
Im no good at soldering so I bought the bord.I put it in and that fixed everything except the green is at a sideways tilt.tryed the convergence manually and automatic.its to far out.
Right now im at $560.00 im not wanting to put anymore money into it.Unless its a cheap fix.please help.
Sorry for the spelling I suck at that and suck at tv repair.
You can email me at mr_h21old@yahoo.com
  • mr_h21old Feb 24, 2008
    went to turn the tv back on and now its bowed in middle and the green gun is not on.I got my parts at partstore.com is that a good place to get parts?
If all three colors move in the automatic convergence mode but they do not move far enough the part you need is the silver can on the convergence board. The part number is on it. It begins with QAL. You can order it from JVC
Posted on Feb 26, 2008
  • 979 Answers
Put the convergence controls at roughly center and manually adjust the green tube for the best pix. Then, go back and set up your electronic convergence and see what that does for you....accordianman
Posted on Feb 24, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Our JVC 56in rear projection tv cut off and when we tried to turn it back on is makes a thumping sound and the blue light on the front blinks and the thumping sound gets louder... Help??
The problem is one of the video drive IC's on the crt boards is bad. These IC's are located behind the front speaker grille. The board connected to the bottom of the crt's will have these ic's on them. They will be screwed into a metal "heatsink" The part number is TDA6111Q
Nov 28, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 48 in rear
Probably the projection guns (my JVC had them fail on me). It started that way and eventually I had a triple image of what was on TV, one in red, one blue, one yellow, and all slightly offset from each other. The fix was new projection guns (thankfully it was under warranty as they were about $300 each).
Aug 08, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC 56in. is broken
id probably get a new model once they are past the 5 year mark its about time for a new one
Jul 22, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
