Question about Formac Gallery 1740 Oxygen 17.4" LCD Monitor
Gallery 1740 Trips out my G5
It seems to have tripped out my whole system and this was incorrectly diagnosed by Cancom as a fault with the power supply in my G5. Having sent it off to their service centre at great expense I was told that the system is 100% ok. It wasn't until I got it home after 2 weeks away & tried plugging the monitor back in when it became apparent it was the screen. The power supply in the Mac just makes a 'click-click click-click click-click' noise, whether I have the screen plugged in on switching the mains on or if I tried to plug the screen in while the Mac is running. My limited electronic experience leeds me to feel this may be a fuse problem in the monitor & the G5 has a safety cut-out built in, but I'm just guessing.
I do not really wish to pay a large sum to ship it to Formac only to find it is non-repairable (as I have already done so with Cancom). It would of course make me particularly unhappy if I find I do need a new screen as it is still under 4 years old & at £410 that's over £100 per year running costs which I find unacceptable.
Any help or advice you can offer would be most appreciated.
Many thanks
Rich Wall
  • 1 more comment
  • Anonymous Feb 27, 2008
    Exactly the same problem with a G4 MDD formac 19" screen The PSU trips out with a tick - tick - tick sound when connected and runs fine with a non ADC monitor. The screens draw 25V at up to 4.5 Amps directly through a 35 pin ADC port which combines power USB and DVI data. I have tried another PSU.
    Suspected Short circuit in the cable plug since the plug has a swivel connector on it which could cause cable wear. Tests indicate no obvious short in the cable so I suspect a transistor or MOSFET in the screen itself, this would cause the current drain to rise beyond spec and the PSU would trip out. Initially our problem was intermittent and now is permanent.
    Next is to get into the monitor's innards. This is no mean feat, these things have no accessible screws just formed perspex with clips which will break if forced. So how?
    Judgin by your report we have the same internal fault.
    Dr Matt
  • whiptash Feb 27, 2008
    tried another PSU.
    permanent.
    Dr Matt
  • tonyh432 Feb 21, 2009
    I have a 4 year old Formac 1900 Raven dvi connected to a G4 and its is now completely dead. I tried it on another G4 with the same result so I assume the monitor is the problem, is there an internal fuse in the monitor that could have blown? thanks,
    Tony
  • 4 Answers
Right I got my formac monitor open by removing the Bezel, it's tricky but not too hard. The casing is suprisingly flexible and forgiving. The clips are backed by a double sided tape on all four edges. Start from the top and give the tape time under tension to come unstuck, it will, a bit like a plaster.
Oh yes, unplug before continuing.
Inside there are four HEX #4 (5/64 inch) screws holding the display inside the chassis. These can be removed, on the back side of the panel is the power/controller board. And remaining in the chassis is the Cold Cathode power board (long thin one on one side). This can be unplugged to get more range on the cables. (remember which way it goes in, I use a marker pen over the plug and socket to show me where to put it back) The Controller board has a number of power components. Firstly there are 5 power diodes, they all seem to respond properly under a meter in my screen. There remains one linear voltage regulator LT1117 and two 500Khz Step down switch mode regulators, LT1374. These devices are most suspect for causing the over current draw. Replace them if you can do this with ease. However most regulators have inbuilt protection. So it is also possible that a support component such as a resistor or capacitor has failed causing the other components to operate outside of their intended parameters. I will post some pics of the board later.
Dr Matt
Posted on Feb 27, 2008
  • whiptash Feb 28, 2008
    So here is the PCB from a Formac 19" display which trips out the G4 as mentioned earlier.
    Alright I did not know fixya would resize it so small so I put it on imageshack.
    [URLhttp://img209.imageshack.us/my.php?image...][IMGhttp://img209.imageshack.us/img209/2451/...[/IMG][/URL]
    Or just open this in another window:
    Dr Matt
Hi, what happened to my G4 is--as i was on it, it just gave in--tic tic tic..black image on the screen and no more power. the computer turned off with the Formac monitor turning black, and then i could not get the mac to turn back on.  turns out it was not the computer, it is the monitor: i can turn the mac on IF the monitor is not plugged into it; but if it is, it'll act as if there's no electricity; and if i attach the monitor while the mac is on, it will turn off the computer at contact.
could this be the same as above, or still a different issue? no idea on how to procede..
thanks for any advice,
cristina
Posted on Apr 05, 2008
Whirlpool gold dehumidifier trips ground fault
Compressor shorted to ground. You can verify by testing continuity from terminals to a piece of copper, or unplug compressor and run system. If no trip obviously bad compressor
Oct 21, 2016 | Whirlpool Heating & Cooling
Maytag GS2126PADW fridge trips safety switch (earth leakage detector) after about 30 minutes. It's not caused by defrost heater.
The house that you live in might be using ADCI instead of GFCI. The newer protection is ARC FAULT DETECTION CIRCUIT INTERRUPTION. It can sense a SPARK and shut down the circuit.
Nov 20, 2014 | Maytag Refrigerators
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Baumattic Bt2760ss oven trips power
Check fan to see that it spins freely. Look for any evidence of rodent nests or damage( chewed wires ) check breakers and wiring to make sure they are properly sized for the oven. Hope this helps.
Jan 18, 2014 | Ovens
Every tme I plug in an extenson cord the circuit breaker trips.
Try a different cord and see if it works ok. If the circuit breaker trips without anything plugged into the extension cord then the chances are that there is a short in the socket of the cord or it is wired incorrectly.
Apr 27, 2011 | Briggs & Stratton Briggs and Stratton...
P0463 and P0499 both codes refer to half circuit high. I keep hearing about good trip equal to zero? have no clue what that means.
Code P0463 refers to the fuel gauge sending unit circuit and P0499 refers to the Canister Purge Solenoid circuit - two totally different circuits.
The reference to "good trip equal to zero" requires the use of a scanner that is capable of reading the data stream from the various Circuits. Many inexpensive scanners are really only "code readers" and will output only the fault codes. They cannot provide you with much of the information required to properly diagnose and repair the problem.
The way a circuit is diagnosed changes completely if the problem is an intermittant problem and is not occuring at the time the circuit is being tested. The data stream will give the fault code and tell you how many trips the vehicle has made without the failure reoccuring. For example, if the circuit failed three trips ago and worked on the next three trips, the good trip count will be "3". If the good trip count is "0" this means that the circuit is failing right now. The troubleshooting charts will send you to different steps depending on whether the fault is current or whether it is an intermittant fault.
There is a lot of misconception in the general public about what fault codes actually do. A lot of people think that you simply plug in the "Magic Box" and it tells you exactly what is wrong with the car and what parts to replace. If anyone finds one of those please let me know...I WANT ONE!!!
What fault codes actually do is give an indication that one of the circuits or systems that are monitored by the computer is malfunctioning. They NEVER tell you what parts to replace. It is up to the person making the repairs to diagnose the malfunctioning circuit or system to determine if any "parts" are actually even needed. Many codes can be fixed by making a simple wiring repair (like cleaning a connector) without replacing any parts.
Dec 05, 2010 | 2006 Chrysler Sebring
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Genius/Prestige/model.NN-P295SF
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that. http://www.eserviceinfo.com/downloadsm/5734/PANASONIC_NN-K652.html
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
Code PO732 2004 Ford Expedition
Trouble Code: P0732 (4.6L V8 VIN W Auto)
Incorrect Second Gear Ratio Print this code dataprint_icon_codes.gif Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Trouble Code Conditions:
Engine started, vehicle operating with 2nd Gear commanded "on", and the PCM detected an incorrect 2nd gear ratio during the test.
Possible Causes:
  • 2nd Gear solenoid harness connector not properly seated
  • 2nd Gear solenoid signal shorted to ground, or open
  • 2nd Gear solenoid wring harness connector is damaged
  • 2nd Gear solenoid is damaged or not properly installed
Refer to the mechanical section to diagnose transmission concerns
Trouble Code: P0732 (5.4L V8 VIN L Auto)
Possible Causes:
Refer to the mechanical section to diagnose transmission concerns.
Oct 26, 2009 | 2004 Ford Expedition
Zanussi tc 7102w and when i turn it on it trips power
element short to ground.. coins hair pins clean try again
Aug 17, 2009 | Zanussi TC7102W Electric Dryer
Formac Gallery 1740 Oxygen 17.4" LCD Monitor Logo
194 people viewed this question
Top Formac Computers & Internet Experts
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
