Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Laptop assembly presario laptop mod 2500
The female plug is not making a connection need to repair it but do not know how to get to it,i have no paperwork for this machine
  • 2 more comments
  • Denis Moogan
    Denis Moogan Feb 24, 2008
    its the port on the right rear of the laptop where the power supply to charge the battery plugs in
  • Denis Moogan
    the problem is that the charger plug is not making a connection to the laptop if you move the plug around while plugged in the charge light will come on indicating that there is something wrong with the recieving plug in the laptop ,i want to get at the plug in the laptop to repair it but dont know how to get the unit apart meaning the laptop casing without damaging somthing in the process
  • Denis Moogan
    the charger is not the problem,i am an electronic tech induustrial, the charger is fine its the connection to the laptop that is the problem,what i am looking for is a description on how to dissmantle the laptop casing to get to the connection at the rear of the laptop, so that i can check it out
  • Denis Moogan
    it is a compaq presario 2500 2531ea , thanks
    Brigadier General:
  • 3,614 Answers
What do you mean for female plug, may i know what is it?
Posted on Feb 24, 2008
  • 3 more comments
  • micromaster
    micromaster Feb 24, 2008
    You can't charge your laptop, or you can't insert the adpator jack to charge?
  • micromaster
    It's that the original adaptor you use before?
  • micromaster
    You can send or bring only the adaptor into the repairshop without your laptop.
    They have a tester unit there so they will know if it is broke or producing a wrong output. They can test and fix the unit there without bringing a laptop.
    You can bring the laptop the moment that you will get the adaptor when they finish fixing it, there you can test the unit in front of the technician together with you and your laptop.
    thanks,
    micro
  • micromaster
    can you give me the brand and the model # of your laptop, i'll send here the schematics.
    thanks,
  • micromaster
    I got this site, but we need to buy for it to get for sevice schematics manual.
    You can try this if you want.
    http://www.9manuals.com/Compaq_SM.htm#pr...
    Hope it helps.
    Kindly regards,
    micro
Hewlett Packard Compaq Presario CQ56 power/charge light blinking orange & will not charge. I replaced the charging unit but it is dtill not charging. What could the problem be?
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Nov 05, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
Intermittent fault (poor connection) on 4.8mm 18.5volts power socket on hp presario a900
It sounds like you just need to replace the laptop's power cord/charger because it's not making a good connection any more.
Jun 26, 2012 | HP Computers & Internet
The female plug in my Compaq Presario (for AC adapter) is broken from the motherboard. Computer still runs, since the battery is about 90% charged. Cab this battery (it has 5 female terminals) be...
i cannot think of a commercial product designed for this. I believe that you either may need to send it in for repairs, or if the pin inside the female end is bent, try bending it back. BE CAREFUL.
Feb 09, 2011 | Compaq Presario 1245 Laptop Charger...
I took apart my Compaq Presario V2630US and I don't know where to plug the cable coming from the screen to the motherboard. The cable contains 2 wires one black the other white each has a female plug that...
Not a problem benpanel.
The cable you're describing is the Wireless Antenna cable.
One Black wire, one White wire.
1) ALL power removed from the laptop. AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
3) Laptop closed, turn it over, open Battery Compartment facing Away from you.
Open the Mini-PCI Compartment Cover.
(Bottom edge of laptop facing you, in the middle)
The Black and White Wireless Antenna cable leads, plug into the Mini-PCI Communications Module.
(Wireless module)
The connectors are designed so they will only plug in one way, and only to the respective connections.
If you would like the Service Manual (Free) let me know in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | Compaq Presario V2630US Notebook
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
Plz explain me exactly for which purpose RJ-45 cable used ?
RJ -45 is a type of connector used on cat5, cat5e....etc cables to connect networked devices...the RJ stands for registered jack but there is really not much you really need to know about it....a RJ 45 JACK is a little bigger than a telephone jack, you'll notice the female type of input on your computer or laptop and the male end will be on the end of the cable that goes into this jack....hope this helps
Apr 13, 2009 | Cat5e Cat 5E Modular Plugs - For Round...
DRIVERS PROBLEM
You can download the drivers for your model laptop from the Compaq WEB site, their support/download page. Make sure you download the Vista version of the drivers.
http://www.compaq.com/cpq-country/cpq_support.html
You will need to use a computer that has Internet connection, when you have downloaded the drivers, copy them and install them on your laptop.
Feb 11, 2009 | Compaq Presario Notebook
C785TU problem related to sound
When you plug the headphones in what happens is that inside of the jack the internal speakers  are disconnected and the sound goes to the headphones. If both are playing either the jack is not inserted far enough or  female plug is loose or defective.  Replace or repair the female plug.
Dec 18, 2008 | Compaq Presario Notebook
Compaq presario 2500 trying to clear power on password
If you have forgotten your password and it is stored in the BIOS, then you can reset the BIOS to the factory default state by removing the BIOS battery, wait for over 1/2 hour for the BIOS to discharge and wipe its contents, then reconnect the battery. You will need to reconfigure the BIOS before Windows opens.
I do not know this model, but if the password is stored in an EEPROM chip then it is near impossble to reset it without knowing the actual password. It would be difficult to remove, if you know a friendly hacker with a piece of hardware that can read the contents of the EEPROM chip and then identify the password, so he can tell you what it is.
Best of luck.
Nov 21, 2008 | Compaq Presario Notebook
Loose USB connection in laptop
You can't do that repair unless you are a experienced circuit tech.
May 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
