Question about Toshiba Satellite M35X-S349 Notebook
Fan Problem - Toshiba Satellite M35X-S349
My fan is continuously running. I shut it down an dthen start it up and it does not stop running. I have opened it up and cleaned it but still SAME ANNOYING PROBLEM!!! Please Help Thank you Joe
  • JoeGuitar Feb 25, 2008
    Thanks TampaNative for the information. I will check again in unit. You are a great help. I do appreciate you.
    Sincerely
    JoeGuitar
    President:
  • 778 Answers
Your fan is running to keep your system (mainly your processor) from overheating. Heat is the biggest enemy of laptops, and most aren't designed to put on your lap (as air intake ports are usually on the bottom and blocking them with your pants, comforter, blanket, etc... will not allow air to circulate causing heat sensing hardware/software to kick the fan into high speed) as that name would suggest. I believe that Notebook computer is the more proper term for most of them, though some are designed with no air intakes on the bottom side, unfortunately yours does. When you opened it up and "cleaned it" did you clean the heat sync and the other components or just the fan? If your PC is in a smoking environment it will have tar build up holding the dust and need a more thorough cleaning than just blowing it out with canned air from the outside (you may want to disassemble it and clean it with a non residual, non petroleum based contact cleaner. Otherwise there are plenty of temperature monitoring softwares out that will tell you what the processor and harddrive temperature are and most have free trials that you may want to try to see if heat is your problem. There is also software available to monitor and even increase/decrease your fan speed.
Good Luck.
Posted on Feb 24, 2008
More Specific Toshiba Satellite M35X-S349 assembly
The long thin wires are the aerial wires that connect to the wireless card. they are normally a black and a white wire and they have a connector that attaches to the wireless card.
Nov 06, 2012 | Toshiba Satellite M35X-S349 Notebook
Toshiba satellite m35x-s114 ( black screen ) , i can hear the fan on start up. is there something i can try to solve the problem.
you need to pull the top of the unit off and unplug the monitor from the main mother bord then plug it back in to re fire it .
Jul 04, 2010 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Boot Recovery Wizard
try f1 f2 if that dont work then f10 f11 or f12 it has to be 1 of them
Oct 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
Laptop fan
Hi. The common problem with these is dust build up in the heatsink fins, but I would have thought the fans would be runnnig hard. try cleaning the dust out by putting a vaccuum cleaner against the grills and around the fan intakes. apart from that, they can have fan failure when trying to run at idle speeds (they may still work at boot) - especially if the fan(s) were running with a slight rattle previously.
Mark
Oct 25, 2008 | Toshiba Satellite M35X-S349 Notebook
Battery Charge and shut down
there's is some problem with the bios setting set the bios setup to default setting to get back to its stable settings
Oct 10, 2008 | Toshiba Satellite M35X-S349 Notebook
HD isnt running
Sounds like your motherboard just died. This is a known issue with Toshiba. They extended the warranty until Nov 7th of 2007, but now it is out of warranty. :-\ You could try phoning Toshiba (good luck getting someone who speaks English) and see if they have any other solutions. Repair is in the neighbourhood of $500 or less, so it seems.
Dec 04, 2007 | Toshiba Satellite M35X-S349 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
231 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
