Question about Cameras
DCZ 520 camera keeps switching off
It does this about 20 seconds after switching on
Found it was under guarantee, so sent it back
thanks anyway
miksu
Posted on Feb 25, 2008
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
Praktica DCZ8LM switches off nearly immediatley. After switching on the red "busy" light comes on for about 3 secs then the goes off. No other indication theat the camera is working. It is not...
If you can, after switching on, quickly press to go into settings, and find the timer switch off spot, and adjust it to make it turn off to never, if possible, and see if that helps. If it does, go back and adjust again to a lesser time like two minutes, or your camera will eat batteries.
Dec 16, 2017 | Praktica DCZ Digital Camera
I CANNOT FIND THE INSTRUCTION MANUAL FOR THE PRAKTICA DCZ 8LM CAMERA
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Sep 25, 2010 | Praktica DCZ Digital Camera
Praktica dcz instruction manual
0e94afd.jpg May be this will help a little bit. Manual can not be found.
Jan 29, 2010 | Praktica DCZ Digital Camera
Praktica dcz 8lm camera: when turned on the light comes on for a second then goes straight back off again. won't take pictures or allow you to view pictures on pc
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 13, 2009 | Praktica DCZ Digital Camera
Screen turns on for about 2 seconds, then turns off followed buy 4 beeps
this sounds like the baterys are going down,, ie flat! you may also be using the wrong type of baterys in it, they eat normal one's!! only use high power type not ni-cads
also look at the programer is it set up in power saving mode??
Oct 22, 2009 | Praktica DCZ Digital Camera
Hi My PRAKTICA DCZ 520 camera is saying CARD LOCKED when i switch it on, i cannot take photos, can anyone help me to unlock it please. Isabella
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 16, 2009 | Praktica DCZ5.0 Digital Camera
Card locked! problem
If your camera uses and SD card. Take a look at the card. There will be a little switch on the side of the card. Move the switch to the unlocked postion, reinsert it in the camera and turn the camera on. It should fix your problem. Thanks for coming to FixYa.
Rob
Mar 17, 2009 | Praktica DCZ1.3S Digital Camera
Resetting
To reset your tt 520 use a straightened paperclip and insert it into the reset hole on the bottom of your tt 520 for 20 seconds.
Hope this helps
Feb 09, 2009 | Tomtom GO 510 GPS Receiver
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
