When trying to turn on my tv it automatically shuts off. when i unplug it and plug it back in, it will give off a spark before going all the way into a plug. what is happening to my tv?
  • 579 Answers
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
On CRT types, figure on replacing the flyback transformer.
Most TV power supplies use a large capacitor on the power input circuit that instantlly charges when plugged in and thus draws a noticable spark. This is normal.
Hope ya fix it!
Posted on Feb 24, 2008
When I turn my TV on, it comes on and says 'no signal' then after about 5 seconds, automatically switches its self off... any idea why?
Most sets will shut down very fast if no signal at all.
If you can before it shuts off try to change input to one of the rear audio video inputs that has something connected to it and turned on.
Failing there and if using a box of some type for signal--unplug it and the set both for a while---plug back both and let each try to boot up.
A total loss of signal or a glitch with the set or a box can confuse the TV set's Microprocessor.
May 30, 2012 | AOC L32H961 32 in. TV
I have an RCA F36669 tv that doesn't stay on.
look to see if the wire is in tv. unplug there 28000 volts there and it hurt use a long handel sew drive to find out unplug tv
Jul 08, 2010 | RCA F36669 36" TV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Turns on and immediately shuts off
check for sleep mode and whether the timer for sleep mode is on or not, if sleep mode is on lets say 30 min or 5 min , ur TV will turn off automatically after that much time
Dec 16, 2007 | Panasonic CT-32HX42 32" TV
My Mitsubishi turns off automatically...
I had the same problem with an RCA, check your sleep mode settings on it, it may have defaulted to 1 min, so it cuts off when it cuts on
Oct 15, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Oct 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
TV makes a repeated cricket sound and won't turn on.
It means that the TV set has a short in it somewhere. The sound you hear is the power supply trying to start up and shutting down. Most likely the Horizontal output transistor shorted because of a bd high voltge flyback transformer went bad. Common problem for these types of sets. Good Luck
Mar 25, 2007 | Memorex MT2271 27" TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
