How to use internet in more than 1 pc from linksys wireless g broadband router model no WRT54G?
You can connect more computers and share the same internet connection by following this setup:
Hi Alex_ghy2000
You can do this several ways.
1) the router has 5 ports on the back. 4 grouped together, one by itself off the side a bit. The one standing by itself is where you want to plug in your cable modem or DSL modem netwprk cable. The other four ports you can plug laptops or desktops directly into for direct Internet access. Easy but lots of wires.
The other way is to still plug your cableor DSL modem into the uplink/WAN port on the back as I described earlier, but instead of plugging cable in, if your laptop is wireless (most are) it will pick up the wireless network and connect.
Linksys has great documentation. Here is a link to get you started. Hope this helps
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
