Question about Frigidaire FEF336BC Electric Kitchen Range
Oven shuts off
I replaced the heating element in the oven which is an Electrolux. After turning the power back on the stove appeared to work. I set the clock, then turned on the oven. As I began to set the temp, I heard a pop sound and the unit completely shut down. I removed the element and reinstalled. Turned the power on again and the unit popped. Any thoughts?
    Problem Solver:
  • 15 Answers
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Posted on Feb 24, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
I replaced the bake element but it will not heat
Have you checked the oven fuse, there should be one on the stove. To check the element power, remove the element from the back where its attached to the stove Remove the element from the wires (Skip this step if you are absolutely sure the element is not working). Attach your meter clips to the 2 wires (meter set set to at least 250Vac), place a piece of cardboard under the screws and meter clips to isolate them from touching any metal parts of the oven. Turn the meter on, set the oven thermostat to 350, you should have at least 220Vac, if you do the power is fine. Test element for continuity, and for a possible short.
Mar 01, 2015 | Dacor Epicure ERD36 Dual Fuel (Electric...
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Miele 310 oven griller works but not the oven. why?
Remember that some parts of a 240 volt stove require two live wires and most of the controls or elements being only 120 volts require just one live wire. Hence the double pole 40 amp breaker must have tripped but does not appear tripped. Just turn it off and back on to reset
Nov 17, 2013 | Miele Ovens
Heating element in the oven appears to burn out, can it be repla
yes but be sure to turn the breaker off or unplug the stove cause the element has power on it on one side all the time and will short out when you take it out. you should see a screw on the plate that the element is attached to in the back of the oven that is how you get it out..
Sep 27, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
Frigidaire FEF336BC Electric Kitchen Range Logo
397 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
