Question about Remington MicroScreen Intercept M-8221 Electric Shaver
Remington M8221 Help
How do I change the battery on my Remington M8221 shaver?
  • kjkennyjohn Feb 24, 2008
    I am techno inclined.
  • Anonymous Mar 27, 2014
    Can not open remington appliance to change battery.
STEPS
• Thoroughly clean the razor cutter area
• Pull off (straight out) cutters and lay aside
• Release spring clips and remove
• Gently pry up and remove rubber boot
• Pry case open starting at cutter end and bending up toward connector end
• Thoroughly clean razor interior area (blow out)
• Pull up motor and remove black oscillator bars
• Pry up the circuit board by releasing the cutter-end catch using a small tool to push it in while prying gently up on the cutter-end of the board and bending up
• Clean the board and turn it over
• Note battery polarity and mark on board if not present already
• Unsolder the battery tabs using unsolder braid. Be careful not to short the electrical circuitry as the batteries are electrically LIVE at this point.
• Remove the old batteries and fully clean off the circuit board solder-pads using unsolder braid.
• Mark the installation date on the new batteries in a place where it will be visible
• Install new batteries, making sure the polarity is correct (cut the tabs to a correct length if they extend too far through the circuit board)
• Solder the battery tabs being careful not to short the electrical circuitry as the batteries are electrically LIVE at this point
• Re-install the circuit board and other parts following the procedure in the reverse order (be sure to put a soft rubber pad over the motor to hold it firmly in place when the upper case half is snapped in place)
• Before installing the metal retaining clips be sure that the rubber boot is fully free and not pinched between the case halves
• Finalize the assembly by reinstalling the cutters and screen
Posted on Aug 24, 2008
Anyone know HOW to change the battery on the Remington Titanium R-950 shaver? Also, I am not sure if the battery is no good or the power cord is no good. Any one have any experience with this shaver?...
It is doubtful that the cord is the problem unless there is visable damage to the cord. Most likely, the batteries are dead. You will find the correct replacement battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change them, take off the back cover by removing the screws. Inside you will see the two batteries. There may be some black tape on the ends. If so remove the tape so that you can get to the tabs on the batteries. Unsolder the old batteries from the wires and solder in the new batteries
If you are not equipped to do this yourself, shaveroutlet.com can do it for you. See link below for information and ordering
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 04, 2010 | Remington Titanium Microflex R-950...
I have no manual. My ms5500 isn"t charging properly and while it is on charge, it gets very hot.
Battery is wearing out. You can change them. See link below for correct battery type from shaveroutlet.com
An easier thing to do would be to purchase a factory refurbished MS-5200 from shaveroutlet.com. See link below. It is the same shaver as the MS-5500 but does not come with the clean/charge base.
http://shaveroutlet.com/shavers/remington-ms-5200-titanium-cord-cordless-shaver-factory-reconditioned.html
Nov 28, 2010 | Remington MS5500 Electric Shaver
How to open remington ms3 1700 electric shaver to change battery and battery type??
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Oct 04, 2010 | Health & Beauty
Change battery
Most MS3 series models were not designed for battery change. The shaver body is glued together and it is extremely difficult to take apart without marring it all up.
shaveroutlet.com sells the shaver body for a very reasonable price. I suggest you consider this item instead. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 02, 2010 | Remington Titanium MicroScreen MS3-2700...
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at shaveroutlet.com. See link below. You will need to order 2 batteries
Sep 25, 2010 | Remington Health & Beauty
I own Remington RS 8943 shaver. Its battery is worn out. Cant recharge.Please help
This model was not made to have the batteries replaced. It is possible but the shaver body will probably come out very scarred in the process. Instead, the following replacement is suggested
http://shaveroutlet.com/remington-ms32700-lower-unit-p-210.html
May 31, 2010 | Remington MicroScreen 3-3000 Electric...
Shaver not turning on
Most likely, the rechargeable batteries need replaced. This model does not run directly from the cord. You can change them yourself if you can do some light soldering.
To replace them, you will need to remove screws on the back to take off the back cover. You can then remove the old batteries.
Batteries can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Feb 07, 2010 | Remington Microflex R-845 Electric Shaver
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
May 25, 2009 | Remington R-9190 Electric Shaver
Remington MicroScreen Intercept M-8221 Electric Shaver Logo
809 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
