Question about GE WBSR3140DW Top Load Washer
No rinse cycle
It stops at the rinse and spin cycle and will go no further.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 24, 2008
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Washer woun't go past washing cycle, just stops
If it is stopping randomly it could be a faulty door switch. If it always stops in the same place on the cycle try to see if you can figure what it is trying to do next,
or example if it cant get through a rinse because it wants to drain the water out but the pump, filter or hose is blocked or if it stops when it wants to heat the water then the heater is faulty. There are examples only.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
