Question about Sharp 25R-S100 25" TV
Sharp 25R-S100 25RS100 SHARP 25" STEREO FRONT/REAR AV
The picture on the T.V. is very dark, we try brighting the T.V. but it's just work a little bit. Waht can we do to fix this problem?
  • davelam May 31, 2008
    My Tv seems to require a long time to warm up.(more than 30mins)
    Initially blur images then slowly becomes sharper.
    Any help appreciated.
    THank you
    Sergeant:
  • 259 Answers
Might have it in closed caption text mode....turn it off in menu.....meder's tv service
Posted on Aug 11, 2010
  • 129 Answers
Good day.
Try to check the crt socket. Also, check for the loose contacts along the Chroma IC. Like wise, there is a screen adjustment on the rear portion of the flyback. Try to adjust the screen.
Response is highly appreciated.
chris
Posted on Mar 29, 2008
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
What does opc stand for
Optical Picture Control. It sets the brightness of the television according to the brightness of the room you're in.
Jun 06, 2011 | Sharp 25R-S100 25" TV
Sharp t v 25r-s100 no power the t v is not turning on
This can be caused by one of two problems. EIther the fuse is blown which is located inside the rear panel next to the power supply aka power inverter. Or the power inverter/supply itself is bad if the fuse is good. It can be tested with a voltmeter.
Dec 31, 2010 | Sharp 25R-S100 25" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Magnavox mwstv66 black & white av
You probably have a bad input selection chip that is killing the coulor on those inputs.
Mar 09, 2009 | Sharp 25R-S100 25" TV
User manual for a sharp cx5182 tv
where is the reset button on my sharp 19" tv it,s my front tv located on my rv.
Digital or Not
The Sharp 25R-S100 TV is a standard NTSC TV with a 181-channel PLL tuning system....which means that it is not digital.
Jan 24, 2008 | Sharp 25R-S100 25" TV
Sharp 25" tv unknown model (no av in)
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Dec 17, 2007 | Sharp 25R-S100 25" TV
No audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Sep 03, 2006 | Sharp 25R-M100 25" TV
Sharp 25R-S100 25" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
