Question about Refrigerators
Fridge/freezer warm, no fan, light's on
A couple of days ago the fridge/freezer apparently stopped working. I was not home but the dog sitter reported finding a puddle on the floor (assuming from the melted ice and such) and both sides warm. Later in the day she plugged it in, it appeared to be working, and by Thursday morning all was well. This morning I got up and opened it...it's warm. Both sides. Light works, water works, but there is no fan, nothing that I can hear running. I unplugged it and plugged it in...nothing. Luckily not a lot of food in there...but what can I do?
  • 3 more comments
  • peacebug Feb 24, 2008
    Adding that it's a Whirlpool Gold GD25DF side by side unit.
    And if it overheated, do I just leave it unplugged for a bit?
    Nothing feels overly warm. I guess I'll leave it unplugged for a bit. Can it overheat if it's really really empty?
    To cap it off, I have a showing on my house today. I cleaned the inside with baking soda and have a bowl of it inside the fridge part...at least that stopped the smell. But I guess I'll have to get someone out here tomorrow or so to fix it. SIGH.
    And THANK YOU!!! If anyone else has any ideas, they are most welcomed.
    President:
  • Refrigerators Master
  • 2,651 Answers
You can remove back cover feel the compressor, is it hot?? perhaps it overheate.
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 24, 2008
    no but if the fan next to the compressor is not working the compreser would overheat, The compressor could just be bad and after running for a few hours shutting down
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Fridge freezer probs
From the sound of it I would looking at the evaporator fan in the freezer. This is what circulates air and actually cools the refrigerator as well as the freezer
May 21, 2012 | Maytag Refrigerators
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Relay clicking, not cooling either side
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
