Question about Panasonic CT-32SL14 32" TV
Panasonic tv CT32SL14J
NO POWER! TV won't come on. Worked last night. Everything else has power but not the tv. HELP!
  • 13 more comments
  • legalbeagle Mar 08, 2008
    found fuse, but small opening not large enough to extract or replace. how can replacement be made? special tool or what?
  • oatmeal1 Mar 17, 2008
    Same issue. All of a sudden TV doesnt' power. Can't find a reset button. Have verified power form source.
    Has anyone found a fix?
  • 23212 Apr 11, 2008
    there is a space to get at the fuse but you can't get in there. I took the back off to get at it, took it out with tweezers but looks ok, now what? The thing weighs a ton!!
    ok cool I'll replace the fuse eventhough it looks ok. No way gonna try going thru that little whole, will take the back off again, only think there is 8 screws, worth doing instead of trying to get my fingers in the hole. Hope it works, let you know.
  • ocurt Apr 18, 2008
    All of a sudden the TV wouldn't turn on. No light came on in the front and a small greenish blue dot was visible in the center of the screen. this dot slowly faded away and now nothing.?????
  • Anonymous Apr 22, 2008
    The TV just shut off while watching. No power.I replaced the fuse as suggested and still no power. Any other ideas?
  • Anonymous May 13, 2008
    My tv worked one night and wouldn't turn on the next day. I took the back off but I have no Idea what I'm looking for.
    My tv worked one night and would not turn on the next day. I took the back off but I have no idea what I am looking for!!
  • Julie Cartwright May 14, 2008
    My tv had the same problem with the power so I changed the fuse and now when you plug it in, it turns on. But the buttons do not work or the red light. then the menu screen comes on and then says picture is locked what do i do now.
  • tecj45912 Aug 20, 2008
    My panasonic tv wont do anything. Wont power up. Took of back of the tv and removed fuse, but fuse looked good, dont know what to do next.
  • jcmeza Nov 17, 2008
    My tv won't turn on but it work this morning. Ican't buy a new one am broke!! somebody help me
  • nblount1 Dec 01, 2008
    TV was working fine. Turned it off and an hour later tried to turn it back on. Absolutely NO power to TV -- everything else works fine. What do I do? (I'm a woman, by the way, and it is HEAVY!) The set is 4 l/2 years old and has been fine up until now.
  • hans9612000 Dec 02, 2008
    TV worked fine this morning. No power later.
  • francins Dec 06, 2008
    I have the same problem. The tv worked fine last night. Today no power no picture, no sound. Mine is 4 years old
  • drmeyer Dec 11, 2008
    I have the back open. Where is the fuse located? What does it look like?
You'd better make sure that there's no power on in the TV by checking the red light in front of it. If it's sure there's no power when the TV's plugging in the outlet, then the problem may be the fuse.
The GLASS fuse locates right after the power cord where is connected to the TV. Using a screw driver to open the back (make sure the power cord already taken out from the outlet !), try to have the power cord side opened as wide as you can. You can use your finger tip to push straight from bottom to up to take the fuse out. For sure, you can see the fuse having the core disconnected in the middle.
To my case, the fuse was 6.3 Amp and 125 Volt, but I can only get the 6.3 Amp- 250 Volt at my local Radio Shack store. However, it's fine to replace with this higher volt fuse.
It costs about 4 bucks for a bag of 4 glass fuses. Worth to try with the "practice" and for having your TV back on again !
~NDo~
Posted on Jan 23, 2009
Thank you to all who posted about this problem w/ Panasonic tv, replaced the fuse and it is working again. Cost $3.00
Posted on Apr 11, 2009
Replace the fuse even if it looks ok. that should only cost a buck or less. since i was afraid to tinker with the tiny opening and end up squashing the fuse i ended up paying 100 bucks to get it re-
placed which fixed the problem. next time i am going to cut a bigger opening (esthetics be damned) with a hack-saw blade and
do it myself. if a new fuse does not do the job big problemo
and not a job for amateur tinkers. good luck
Posted on Apr 11, 2008
  • legalbeagle Sep 26, 2008
    greetings fellow victims. well, it happened again. blown fuse! with no apologies i did what i threatened to do after the first event. yes, against the advice of the more talented of our club i took a hacksaw
    blade, cut out an opening, removed the fuse(which looked ok but was not) and back in business.
    to rationalize my seemingly bizarre solution my tv armoire has a 32.1" opening. getting to the backside is a chore in that this thing weighes a ton making it difficult to give it a twist to get to the rear for an entry point. also the idea of getting into the set via the front by separating the screen(tube) from the the chassis brings up memories of a set placed upon a soffa, tumbling forward , tube side forward (the heavy side of any tv) offering the opportunity to buy a new set. although still smarting
    at my undeserved "apprentice" ranking the snobby ranking committee will likely give scan recognition to imagination and true grit.
    Problem Solver:
  • 8 Answers
Is there a red LED light on the the front? if there is none? the fuse the main board could have been busted. u could try to open and see if its really busted then replace the fuse with the same ampere and voltage rate indicated in the fuse.
if your LED is blinking it is indicating a voltage trouble on the primary circuit, powering up is the problem , and in this circuit a component might have been defective already or the power up regulator need replacing , power up regulator also called switching regulator is the usual defective in the primary circuit.
you could bring your TV to a Panasonic service center to really inspect more the TV.
Replace the fuse thats the problem and is very cheap you can find the fuse in Radio Shak
Posted on Jan 12, 2009
Bought this TV brand new in 2004. All of a sudden today, 6 years later, it would not power on. I figured it was just done, dead. The TV is so large and heavy that I am unable to even remove it from my home and I was ready to place an ad for someone to come take it for free just to get it out of here. But then I found this page and following the suggestions posted, I took off the back of the TV, removed the fuse (which was in fact burnt out), went to Radio Shack, purchased a pack of 4 replacement fuses for $2.99, replaced the fuse, put the back of the TV on again, and the TV powered up like new!!!!! I was SO excited because I CANNOT afford a new TV, so I was going to have to bring the small bedroom TV out to the living room to replace this one. Thank you to poster "NhDo" for the most thorough advice!!!. NOTE: The Radio Shack near me also did not carry the 6.3 amp 125 volt fuses and I purchased and used the 6.3 amp 250 volt fuse and it is working perfectly!!! THANK YOU EVERYBODY FOR POSTING THESE SOLUTIONS!!!
Posted on May 30, 2010
Comeon. Don't saw a hole. Take the screws out, including the 2 around the av connections. The back comes off very easily I was pleased to discover.
Posted on Sep 23, 2008
I looking flyback transformer for panasonic 32" tv model#ct32sl14j . please help!
part number should be TXFFT05GSER
Found it here at vance baldwin but not in stock you can call them to check availability or do a search for that part number and a number of places show up.. MCM etc...
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5390250&smodel=CT32SL14J
Oct 17, 2010 | Panasonic CT-32SL14 32" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Feb 24, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Panasonic CT-32SL14 32" TV Logo
1,918 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
